I'd like to see clear definitions of which colors correspond to which directions on
the P8 normal map. I've tried a few available normal maps, and they don't seem
to work. (The P8 manual PDF doesn't help, naturally.)
My python page
My ShareCG freebies
somebody will hafta try a normal map in poser 8 or later to see if there's edge fall-off and which
normal deflection is associated with r, g, and b. links to two free normal map generators were
posted in carrara forum, but they apparently don't know if a normal map has the same edge
fall-off as a bump map. meaning a bump map doesn't cause apparent displacement (on render)
of polygons whose normal is at right angle (on edge) to camera view.
some reasons for switching to poser 8 (OS X):
red = x
green = y
blue = z
In the world of normals, however, there is some disagreement about whether more green is up (positive y) or down. However, it's a simple matter to flip it using nodes. (2 if I recall correctly) I posted this in a thread a long time ago. I'll try to find it.
Okay, thanks. I'm basically trying to extend my well-established trick of using
the P node to generate displacement maps from modelled surfaces. Seemed
like it should be possible to make normal maps by the same trick, using the
xyz components of N instead of P, controlling different colors. But without a
basic guide I couldn't tell what needed to go where.
My python page
My ShareCG freebies
Attached Link: http://www.smart-page.net/smartnormal/fl10.htm
it's like a poser4.bum file but with extra colour (blue). gamers are excited about it because they believe it can add realism to low-poly models, even tho, like poser 4 bump map, it doesn't show round the outline of object. as opposed to displacement map, which is either in-or-out like bump map, but which shows round the outline (edges).Normal maps do not use RAM like displacement mesh would. Normals would render quicker as in they don't require nearly as much CPU time because displacement is not happening, just a more detailed bump is.
Poser 7 can it use normal maps? Mac 10.5.8
MacBook Pro OSX El Capitan Ver 10.11.6
