Wed, Nov 20, 12:36 AM CST
Subject: Lighting in a 360 degrees animation?
Gangreedo ( ) posted Sun, 25 July 2010 at 8:28 AM · edited Wed, 20 November 2024 at 12:25 AM
  Hi,
 I have a quick question. Let me first say I am a total newb when it comes to lighting - I've only been using pre-made sets.
 I'm working on an animation that has the camera doing a 360 degrees flyaround, but my lighting is only lighting the front, it doesn't rotate as I move camera. Is there an eas way to accomplish this?
 Thank you very much. :]
Adom ( ) posted Sun, 25 July 2010 at 8:55 AM
HI, try this:
select first light,
if it is INFINITE light then go to its PROPERTIES tab and change light's type to SPOT,
now go to MENU->OBJECT->CHANGE PARENT (or from PROPERTIES tab select SET PARENT button which will appear when you change the light's type)
select camera you want as a parent - and ok
change back light to its original type.
Follow above steps for all lights you want to follow your camera - should work.
markschum ( ) posted Sun, 25 July 2010 at 9:13 AM
For a 360 degree product shot , I would set up lights and camera , and then rotate the product rather than animate the camera.  THis works fine for things like cars or clothes.
If it needs to be a real flyaround then you either need to provide a fairly even 360 light which is not that hard (3 spotlights even placed ) or parent the lights to a ball prop and rotate the ball as you move your camera. (position the ball prop out of camera view above your scene)
PhilC ( ) posted Sun, 25 July 2010 at 10:18 AM
file_456527.txt
I have these as my default lights. Four infinite lights parented to the main camera. That way where ever I look in the preview the subject will always be evenly illuminated.
Hope that helps.
PhilC ( ) posted Sun, 25 July 2010 at 10:19 AM
and here is the thumbnail.
