Carrara F.A.Q (Last Updated: 2025 Feb 13 6:48 pm)
It's fairly easy to do this:
Step one: It can be done only in the vextex room
Make your main cube and make your doorway cube, move the doorway cube inside the main cube so that part of it is still sticking out. Then hold down on the left mouse button and draw to enclose both the main cube and the doorway cube. Press down on both the ctrl and alt keyboard tabs at the same time and select a point on the main cube AWAY from the merger. That point should change color. Then go to your boolean drop down menu and select boolean substract operation. The hole is formed inside the main cube. Jan
Thanks so much! I appreciate the quickness too!
Kevin
The most exciting phrase to hear in science, the one that heralds
new discoveries, is not 'Eureka!' (I found it!) but 'That's funny
Isaac
Asimov (1920 - 1992)
How does one bring from the assembly room into the vertex modeling room two objects.... Only one object seem to go but not the other.... When I try starting from the modeling room, things are a bit strange...
Mark
When making an object in Carrara (8), how are booleans done? For example, were I to make a simple box and want it hollow with an entry "hole (door/window) how would that be done in Carrara? In Bryce it's a simple matter, but I don't see anything that clues me in on how to do it in Carrara.
Sorry for the "noob" questions.... Sure is a learning curve to Carrara...
Thanks (again!)
Kevin
The most exciting phrase to hear in science, the one that heralds new discoveries, is not 'Eureka!' (I found it!) but 'That's funny ...'
Isaac Asimov (1920 - 1992)
