Thu, Feb 20, 2:22 PM CST
Forum Moderators: RedPhantom
Subject: Poser Pro 2010 SR1 NOW AVAILABLE!!
LostinSpaceman ( ) posted Thu, 22 July 2010 at 4:27 PM · edited Thu, 20 February 2025 at 3:55 AM
Dizzi ( ) posted Thu, 22 July 2010 at 4:58 PM
Don't forget to take the survey on that page, too ;-)
Malysse ( ) posted Thu, 22 July 2010 at 5:54 PM
Excellent! This service release has already proved worthwhile by stopping Poser from crashing when certain Python scripts are run. Thanks for the heads up.
TrekkieGrrrl ( ) posted Fri, 23 July 2010 at 2:02 AM
 Oh typical JUST on the day where I'm away from my ordinary computer all day LOL!
I wanna go hooome!
Thanks for the heads up!
Mazak ( ) posted Fri, 23 July 2010 at 2:42 AM
:woot: Thank you for heads up.
Mazak
Google+ Bodo Nittel
ice-boy ( ) posted Fri, 23 July 2010 at 2:55 AM
please god  tell me they fixed teh setup room
Mazak ( ) posted Fri, 23 July 2010 at 3:02 AM
Smith Micro Software, Inc. and the Poser team are pleased to announce that the Poser Pro 2010 Service Release 1 (SR1) is now available for both Macintosh and Windows. SR1 will update your non-beta version of Poser Pro 2010 English to the latest version 8.0.3.11916.
SR1 offers several enhancements and addresses known issues present in the following areas:
-     Rendering improvements
-     General performance and stability updates and improvements
  •     Content Library improvements
-     Python improvements
-     Material Room improvements
-     Animation improvements
-     Queue Manager improvements
  •     Rigging improvements
In order to download Poser Pro 2010 SR1 or receive technical support for the product, you must have registered your Poser Pro 2010 application serial number. If you have not yet done so, please register now at:  http://www.smithmicro.com/support/product-registration.aspx
With your registered Poser Pro 2010 serial number, you can access and download SR1 for
Windows: http://my.smithmicro.com/win/poser/updates.html
Macintosh: http://my.smithmicro.com/mac/poser/updates.html
Stuffit Connect name change note: The service has been renamed to SendStuffNow. Active accounts will automatically migrate to the new service, and support within Poser Pro is functionally the same as in its prior release, with the only change being the name displayed in the interface.
Recommended workarounds for known issues:
  • To improve rendering performance: Single-thread renders are less efficient than multiple threaded renderings. To reduce render times, enable multiple threaded rendering. Reduce bucket size to decrease render times.
SR1 Enhancements and Fixes, by category:
________________________________________________**
General
  • Improved conforming when the number of children does not match between object being conformed and body part being conformed to.
  • Figure->Create full body morph is now undoable
  • UI preferences were incorrectly written when shutting down Poser while it was minimized
  • Fixed instabilities when reparenting/rearranging objects in hierarchy palette
  • Uninitialized variable was causing occasional crash when new scenes were created. This could affect file new and walk designer
  • Menu commands for setting background and foreground colors work correctly
  • Fixed issues with out of sync app menu item states to improve Undo
  • Enabled Display Origin option.
  • Fixed case where automatic update check could cause instability (Mac OS X only).
  • COLLADA: Enabled Invert Transparency Map export option (Mac OS X only).
Library
  • Fixed library drag/drop of files and bitmap resource issues for files with non-western/non-ASCI characters in their paths
  • Support enabled to preserve added runtime libraries on external hard drives upon launch even after external drives are removed.
  • Fixed display of  “Add to Library” button in AIR library on Mac OS X.
  • Enabled drag & drop from Library when SreeD preview rendering is selected.
Material Room
  • Material room: Reflection_Lite_Mult now disabled by default for newly created materials. Existing files and content will not be affected.
Face Room
  • Resolved: Disabling superfluous app menu items could trigger crashes
  • Exporting textures from Face Room works correctly.
Cloth
  • Fixed case where cloth simulation with multithreaded bending enabled could cause instability.
Rendering
  • Faster raytracing in scenes with complex geometry
  • FFRender works properly on PowerMac G5 even when 64bit QTKit is missing (Quicktime update 7.6.6 on 10.5 omits the 64bit PPC version of QTKit)
Animation
  • Creation of extraneous key-frames on lights no longer occurs.
Queue Manager
  • Enabled multithreading configuration in Queue Manager preference file
Rigging/Set-up
  • International decimal point symbol changes caused influence zones to behave erratically in the joint editor.
PoserPython
  • Added new Python methods to enable/disable IDL from scripts.
  • Resolved: Python script dialog instabilities when running in 64 Bit.
PoserFusion
  • Fixed a problem writing .max files with embedded Poser scenes on 64 bit.
TRADEMARK & COPYRIGHT NOTICE
Poser, Poser Pro, the Poser logo, and the Smith Micro Logo are trademarks and or registered trademarks of Smith Micro Software, Inc. Poser copyright © 1991-2010 All Rights Reserved. All other product names are trademarks or registered trademarks of their respective holders. Licensed product.
Mazak
Google+ Bodo Nittel
Mazak ( ) posted Fri, 23 July 2010 at 4:07 AM
The Cinema plug-in did not work :sad:
Mazak
Google+ Bodo Nittel
ratscloset ( ) posted Fri, 23 July 2010 at 9:04 AM
Quote - The Cinema plug-in did not work :sad:
Mazak
Make sure you installed the SR 1 Update for Poser Pro 2010 first, and you rebooted after installing the SR 1 Update.
If you still have issues, contact Support.
ratscloset
aka John
Mazak ( ) posted Fri, 23 July 2010 at 9:42 AM
Quote - > Quote - The Cinema plug-in did not work :sad:
Mazak
That did not help. The plug-in start but I can't load a Poser scene.
But no problem I use the InterPoserPro plug-in, that work and is always the better one!
Mazak
Google+ Bodo Nittel
TrekkieGrrrl ( ) posted Fri, 23 July 2010 at 12:00 PM
 Soooo since I'm still not home..-has the Joint Parameter-editing been fixed?!
IsaoShi ( ) posted Fri, 23 July 2010 at 12:59 PM
Quote - Reduce bucket size to decrease render times.
This can't be right. Smaller bucket size always used to mean lower memory requirement but longer render times due to bucket management overheads. Please explain!
ice-boy ( ) posted Fri, 23 July 2010 at 1:49 PM
Quote -  Soooo since I'm still not home..-has the Joint Parameter-editing been fixed?!
'' * Rigging/Set-up*
    • International decimal point symbol changes caused influence zones to behave erratically in the joint editor.''*
from what i understand they are saying that they did. i still need to download and try it out.
-Timberwolf- ( ) posted Fri, 23 July 2010 at 2:29 PM
My Poser Fusion keeps crashing too.It kept crashing before and after the SR.One possible reason :It cannot deal with different runtimes.I once made it to load Allyson but she comes with black textures.When I contacted S-M support months ago , they answerd that they couldn't reproduce that issue --- end off.
TrekkieGrrrl ( ) posted Fri, 23 July 2010 at 2:41 PM
Quote - > Quote -  Soooo since I'm still not home..-has the Joint Parameter-editing been fixed?!
I saw this but wasn't sure if it concerned the issue *I had. Well apaprently it DID :D I just tried and the Joint Editor now behaves like in any Poser version :D YAAAAAY!
Darboshanski ( ) posted Fri, 23 July 2010 at 2:48 PM
Quote - My Poser Fusion keeps crashing too.It kept crashing before and after the SR.One possible reason :It cannot deal with different runtimes.I once made it to load Allyson but she comes with black textures.When I contacted S-M support months ago , they answerd that they couldn't reproduce that issue --- end off.
Kinda the same response after playing with SM about my camera problems. They told me it was a video hardware problem. Well new OS, new video hardware and a clean install of PP 2010 and guess what? The problem is still there.
My Facebook Page
ice-boy ( ) posted Fri, 23 July 2010 at 3:16 PM
Quote - > Quote - > Quote -  Soooo since I'm still not home..-has the Joint Parameter-editing been fixed?!
''* Rigging/Set-up*
so it was fixed?
TrekkieGrrrl ( ) posted Fri, 23 July 2010 at 4:47 PM
Quote - > Quote - > Quote - > Quote -  Soooo since I'm still not home..-has the Joint Parameter-editing been fixed?!
''* Rigging/Set-up*
so it was fixed?
Apparently, yes :)
Darboshanski ( ) posted Fri, 23 July 2010 at 4:57 PM
The problem I am having is that when I have the library window up, and say I apply a pose, the library window will minimize to the tool bar and the pose will not take until I maximize the library window again then then pose will work. Same goes for conforming clothing, hair and any props that are parented to the figure. I also have cameras that will not rotate the screen when I use the dials for that camera. As a matter of fact outside of somethings that do work better I am having more problems then I did before I installed the update. No other apps I use gives me such fits only PP2010. So I don't know what to say all the necessary drivers for my graphics card are updated.
Windows 7 64-bit
GT240 1 gig video card
8 gigs ram on a quad core CPU.
Unlike Vue which has the ability to roll back an update without un-installing the program PP 2010 will now have to be un-installed and re-installed to get rid of this SR-1.
My Facebook Page
ratscloset ( ) posted Fri, 23 July 2010 at 6:00 PM
Poser Fusion can handle external Library Locations, but they must be available to the Host Application as well. Depending on your Operating System, this can be a Security Setting or Shared Setting.
This is a good test... Use Collected Scene Data and save to the Shared Folder and then open that one using Poser Fusion and see if the issue is resolved. If you do not want to mess with settings, you can do that to use Poser Fusion, or you can check your settings for your Library Locations to see if you can resolve the issue. I have seen this with a few users, but most were able to resolve either using the workaround or by adjusting Settings.
If you still have issues, Contact Support again and put attn John... I may have been the one to help, but I normally do not say that I can not assist because I can not duplicate. I normally ask for more details, since it is often specific factors that lead to this type of issue.
ratscloset
aka John
ratscloset ( ) posted Fri, 23 July 2010 at 6:07 PM
Quote - The problem I am having is that when I have the library window up, and say I apply a pose, the library window will minimize to the tool bar and the pose will not take until I maximize the library window again then then pose will work. Same goes for conforming clothing, hair and any props that are parented to the figure. I also have cameras that will not rotate the screen when I use the dials for that camera. As a matter of fact outside of somethings that do work better I am having more problems then I did before I installed the update. No other apps I use gives me such fits only PP2010. So I don't know what to say all the necessary drivers for my graphics card are updated.
Windows 7 64-bit
I have not seen this, but I do not doubt you are experiencing it. I am not sure if I responded to you before, but contact Support again with this issue.
The hardest thing about dealing with issues that we only have one report is finding the cause. If it can not be duplicated, it is nearly impossible to find the cause. This is why it is important for anyone with an issue to report it. Sometimes it is a series of specific steps that you may not think twice about, that leads to the issue. That is why it is also important to be very specific about the steps.
Several of the weird ones have been found after a few additional reports. One I remember was a conflict with the default settings of one of the Free AV programs. The creators of that program told the user that they needed to buy the purchased version to be able to make changes to those settings. This helped several other users that reported the same issue. Some chose to change AV Programs, some chose to upgrade to the Paid Version, but all were resolved because of the feedback.
ratscloset
aka John
Darboshanski ( ) posted Fri, 23 July 2010 at 8:17 PM
It's all cool as long as I keep the library window up in front and not minimize it. It's not a huge biggie outside of that little thing I am happy.
My Facebook Page
oddbob ( ) posted Fri, 23 July 2010 at 10:59 PM
Won't accept my serial. I'm hugely surprised...
edgeverse ( ) posted Sat, 24 July 2010 at 7:00 AM
I am having the same problem. Strange, huh? I even contacted support about it.
3D Digital Comics & Art/My homepage
http://www.edgeversemedia.com
aeilkema ( ) posted Sat, 24 July 2010 at 9:49 AM
I took the survey, but not going to download the SR until we see some feedback about it.
Food for thought.....
-Timberwolf- ( ) posted Sat, 24 July 2010 at 10:46 AM
Poser Fusion only crashes in 64bit mode.There is a workaround to load the Figure in 32bit mode , save it as a c4d file and then to reload it in 64bit c4d.
Darboshanski ( ) posted Sat, 24 July 2010 at 12:46 PM
What is funny is when I try to grab a screen capture of these strange happenings for SM to see the problem corrects itself before the capture can get it. I think I'll just sit here working in PP2010 and when it starts acting up I'll grab the camera and take a video clip of it. Maybe it's the only way for SM to actually see the problem since it's hard to describe it.
My Facebook Page
Willber ( ) posted Sat, 24 July 2010 at 5:58 PM
 Won't take serial on the SM site?
Just close down your browser and start again.
Seems if you made any error when entering the serial number or other info, this wrong info is cached in the browser... at least that's all I can think of.
I had this issue and could not get past the serial number entry until I restarted IE Explore.
Oh, another thing, some browsers, Chrome, Firefox etc, don't play nice with some web sites when entering serial numbers etc. So try IE instead.
TrekkieGrrrl ( ) posted Sat, 24 July 2010 at 6:03 PM
 I'm using Chrome and had no problems entering my serial number (well yes but that was because stupid me entered the Poser 8 serial at first L)
Once I found out that I'd thewrong Poser open.. it was a breeze.
Aeilkema.. what kind of feedback do you want?
I've been using it now for a day and hasn't found any bad behaviour, but on the positive note the joint editor is fixed.
edgeverse ( ) posted Sat, 24 July 2010 at 6:56 PM
Tried both IE and FF and still wont take serial. makes no sense.
LostinSpaceman ( ) posted Sat, 24 July 2010 at 7:07 PM
Quote - Tried both IE and FF and still wont take serial. makes no sense.
Are you certain your registered your serial number with the SM site when you bought it?
edgeverse ( ) posted Sat, 24 July 2010 at 7:08 PM
Yes, positive.
LostinSpaceman ( ) posted Sat, 24 July 2010 at 7:15 PM
You should go to the support section and enter a ticket then.
edgeverse ( ) posted Sat, 24 July 2010 at 7:18 PM
I did that last night.
LostinSpaceman ( ) posted Sat, 24 July 2010 at 7:21 PM
Well it's the weekend now. You won't hear back from them before Monday. I'm sure they'll sort you out then.
ratscloset ( ) posted Sat, 24 July 2010 at 8:47 PM
Anyone and everyone that runs into an issue with it accepting their Code, contact support with your Code and Order Number. Put a Subject of Attn John... SR1 Code not accepted.
I will look for them and get you a solution.
Thanks
ratscloset
aka John
LostinSpaceman ( ) posted Sat, 24 July 2010 at 10:04 PM
Thanks John! You work too much! 😉
mackis3D ( ) posted Sat, 24 July 2010 at 10:29 PM · edited Sat, 24 July 2010 at 10:30 PM
Same problem with the SN in Firefox but it worked in IE when I retyped it, maybe something with JavaScript that often has issues with Firefox. And sadly SmithMicro uses it for the dialogue field to type the numbers in. Why not an update as the others before without SN? I'm unnerved to always find numbers for anything the whole day, when I phone with bank, with the telephone company etc.
TrekkieGrrrl ( ) posted Sun, 25 July 2010 at 4:56 AM
 Well at least when it comes to Poser it's EASY to retrieve the serial, even in a cut-and-paste-able format. Open Poser, go to Help - Personalize and volià, there's your serial.
Darboshanski ( ) posted Sun, 25 July 2010 at 10:13 AM
Quote - > Quote - The problem I am having is that when I have the library window up, and say I apply a pose, the library window will minimize to the tool bar and the pose will not take until I maximize the library window again then then pose will work. Same goes for conforming clothing, hair and any props that are parented to the figure. I also have cameras that will not rotate the screen when I use the dials for that camera. As a matter of fact outside of somethings that do work better I am having more problems then I did before I installed the update. No other apps I use gives me such fits only PP2010. So I don't know what to say all the necessary drivers for my graphics card are updated.
Windows 7 64-bit
I have already been all through this before with SM and tech support. And unless you are sitting right here with me when this all goes down there isn't much I can describe except to have a video camera running the whole time I am  working with PP2010. When I first brought this to the attention of SM's tech support I was using Vista 64-bit and a different video card. SM felt it was a hardware issue and wanted me to pull my card out and run PP2012 on just vista's video drivers alone. Then put my card back in and start from square one.....no improvement.
So now this machine has had Vista removed and in its place a fresh install of windows 7 64-bit
and a brand new video card. The same problems I had with Poser Pro 2010 using Vista and the so called hardware issue are still here. It is definitely an Open GL issue and it has to do with this floating library crap in windows 7 64-bit. All the trouble goes away when PP2010 is in Scree this is why I say it's an OpenGL issue. I find it confusing that my other apps that are OpenGL dependent i.e. Vue Infinite, have zero issues the older version of Poser Pro and Poser 7 have zero issues but when I run Poser 8 or Poser Pro 2010 I get all these strange, crazy conforming issues, crazy camera problems like half the screen will rotate with the camera and half will not and a bunch of other things I have already reported to SM already. We spend 3 weeks going back and forth on these issues and as I said unless someone from SM want to sit in my studio as we work with PP2010 to see this first hand there is not much I can say I haven't already. So I am at a loss...lol.
My Facebook Page
Haarspalter ( ) posted Sun, 25 July 2010 at 3:40 PM
Cant download the SR1.
I become the message "Your shopping-card is empty" ???????????
What is this for a crazy bullshit with this SR??
TrekkieGrrrl ( ) posted Sun, 25 July 2010 at 4:24 PM
 Haarspalter. Are you sure you're logged in before adding it to the cart?
Love your name BTW ^_^
Darboshanski ( ) posted Sun, 25 July 2010 at 4:32 PM
Quote - Cant download the SR1.
For me the way I got the SR1 update was to be logged into my Content Paradise account as well as the link for the SR1 update at Smith Micro. For some reason the SR was sitting in my Content Paradise account and not at Smith Micro.
My Facebook Page
edgeverse ( ) posted Sun, 25 July 2010 at 5:27 PM
Odd thing is, its not accepting my serial. Makes no sense.
ratscloset ( ) posted Sun, 25 July 2010 at 7:40 PM
Quote - > Quote - Cant download the SR1.
The Access to the stores are the same. One Account can work in both stores.
ratscloset
aka John
edgeverse ( ) posted Sun, 25 July 2010 at 9:04 PM
I got the update finally. SM messages me back via email with a new serial. All is good now. I didnt see a difference in rendering though.
Zaycrow ( ) posted Mon, 26 July 2010 at 8:02 AM
I also got a new serial as it turned out my "old" serial was not able get updates on their site.
edgeverse ( ) posted Mon, 26 July 2010 at 8:28 AM
Strange, huh? I mean, I have a full version with serial. Now I had to change the serial to the new one I was given.
Darboshanski ( ) posted Mon, 26 July 2010 at 8:28 AM
My buddy had the same problem with his serial number and it turned out he was still using the Beta version of Poser Pro 2010. So SM fixed for him too.
My Facebook Page
oddbob ( ) posted Mon, 26 July 2010 at 1:25 PM
Also received a new, working serial. Impressively quickly too, thanks.
I can now use all my python scripts in the 64 bit version without the program crashing, before it was like script roulette.
GeneralNutt ( ) posted Tue, 27 July 2010 at 1:45 AM
Had a similar problem to this prior to SR1. I can't use the library so that had nothing to do with it for me. It happened for about 2 days, then poof went away. I have no idea what I did different for those two days.
