You could use meshlab. It can lower the polly count while maintaining the shape. However it triangulates the modell. meshlab.sourceforge.net/
____________________________________________________
"The true sign of intelligence is not knowledge but imagination".
Albert Einstein
What are you doing with the figures? If you're just using them as mannequins to build for instance clothes around, simply omit the head when exporting.
no I am wanting to bring them into other programs for sculpting and rigging etc. my big problem is I only been doing this 3D stuff for a little over a month and so not very good at setting up faces for retopology so when I bring it into zbrush for subdividing it will divide evenly so I am able to detail the rest of the head.
right now I can only get 2 mil polys out of the head because the face subs more than the rest of the head. I should be getting abt 6 mil polys.
so until I can clean up the faces I kinda get screwed on doing high detail for my mapping etc.
Joe
here is a couple renders I did from a bust I pulled off just to show what I want to end with.
is there a way to adjust poly counts when exporting poser models? the bodies are ok but the faces all have obscene poly counts and its a pain retopoing every time just because of the face.
joe
