Sun, Nov 10, 2:57 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2024 Nov 05 6:06 am)
Carrara Free Stuff here.
Subject: Problems with the spline modeler grid...
Techyman ( ) posted Mon, 02 August 2010 at 9:11 PM · edited Sun, 10 November 2024 at 2:49 AM
I've just started using C8Pro and I'm having trouble using the grid in the spline modeler.  I need to draw a large model - 15ft long - but with accuracy down to the inch.  I tried adjusting the grid down to one inch increments, but when I zoom in to work on the details, the grid sets to a different measurement.  How do I zoom in, but retain the new grid measurements?
Any help will be greatly appreciated.  Thanks in advanced.
sparrownightmare ( ) posted Mon, 02 August 2010 at 9:25 PM
I set my modeling box to 20 feet, then I set the grid to spacing 1 every .13  That's about as accurate as you can get it.  I just wish the stupid thing wouldn't keep resetting.
benney ( ) posted Tue, 03 August 2010 at 7:45 AM
It is for reasons like this that I eirther use the vertex modeller or turn to my external modeller  "Hexagon"
sparrownightmare ( ) posted Tue, 03 August 2010 at 8:26 AM
Nah.  I stink with the vertex modeler.  I never could quite get the hang of it.  With a little creativity you can do almost anything in spline models that you could do in the vertex room.  I really need to figure it out though.
benney ( ) posted Tue, 03 August 2010 at 8:32 AM
Well if you get stuck and you need an extra pair of hands for a project just ask. Otherwise, just keep practising and you will get there.
sparrownightmare ( ) posted Tue, 03 August 2010 at 8:34 AM
Half my issue is that the manual for Carrara is not very useful.  It only described things in a very general way and there is not much actually useful specific info.  I taught myself the rest of the program, but the vertex room just confuses me too easy lol.
benney ( ) posted Tue, 03 August 2010 at 8:46 AM
I got myself up to date with carrara by using the "Carrara 5 pro handbook" by "Mike De La Flor". Though it was written for version 5 it can still be applied to the latest versions and actually helps to clear up some everlasting questions and reveals a few hidden secrets too. Once I had read the manual and completed the tutorials it was just a case of expanding what I had learned using the carrara help file, though I have to agree with you and say that it is lacking in true structure for the beginner etc.
MarkBremmer ( ) posted Tue, 03 August 2010 at 8:50 AM
 Carrara's spline modeler is not designed for precision. When I need absolute accuracy, I'll create the shapes in illustrator and then import them into the Spline Modeler instead. This a great way to leverage the many drawing capabilities of Illustrator to make some complex shapes that would be near impossible to do well in Carrara alone.
sparrownightmare ( ) posted Tue, 03 August 2010 at 9:21 AM
I wish I had Illustrator.  I spent my yearly 3D budget on C8 Pro this year LOL.  When I run into a complex shape, I generally break it down into manageable components, and model each element separately.  But you are definitely right about precision.  It requires a lot of tweaks and fussing to get parts to fit in with each other properly.  I really need to learn the vertex room.  And I definitely need to learn proper UV Mapping...  I really stink at that as well.  I'm pretty much self taught since Ray Dream, so I am probably quite a bit behind the curve on some elements.
