Carrara F.A.Q (Last Updated: 2024 Sep 07 1:44 am)
I got myself up to date with carrara by using the "Carrara 5 pro handbook" by "Mike De La Flor". Though it was written for version 5 it can still be applied to the latest versions and actually helps to clear up some everlasting questions and reveals a few hidden secrets too. Once I had read the manual and completed the tutorials it was just a case of expanding what I had learned using the carrara help file, though I have to agree with you and say that it is lacking in true structure for the beginner etc.
Carrara's spline modeler is not designed for precision. When I need absolute accuracy, I'll create the shapes in illustrator and then import them into the Spline Modeler instead. This a great way to leverage the many drawing capabilities of Illustrator to make some complex shapes that would be near impossible to do well in Carrara alone.
I wish I had Illustrator. I spent my yearly 3D budget on C8 Pro this year LOL. When I run into a complex shape, I generally break it down into manageable components, and model each element separately. But you are definitely right about precision. It requires a lot of tweaks and fussing to get parts to fit in with each other properly. I really need to learn the vertex room. And I definitely need to learn proper UV Mapping... I really stink at that as well. I'm pretty much self taught since Ray Dream, so I am probably quite a bit behind the curve on some elements.
I've just started using C8Pro and I'm having trouble using the grid in the spline modeler. I need to draw a large model - 15ft long - but with accuracy down to the inch. I tried adjusting the grid down to one inch increments, but when I zoom in to work on the details, the grid sets to a different measurement. How do I zoom in, but retain the new grid measurements?
Any help will be greatly appreciated. Thanks in advanced.
