Tue, Feb 11, 10:04 AM CST
Subject: Pointy teeth for G2 women?
sdsullivan ( ) posted Mon, 02 August 2010 at 11:25 PM · edited Tue, 11 February 2025 at 10:02 AM
 I have a render where it would be really great to have some shark-like teeth for G2 women - but I'm having no luck finding such a product.
Any suggestions?
Would it be possible to do this with a texture for the teeth if all else fails?  (Or is that going to be amazingly hard.)
Your help & advice appreciated!
 Stephen D. Sullivan
www.stephendsullivan.com
Adventure guaranteed.  (Monsters optional.)
lesbentley ( ) posted Mon, 02 August 2010 at 11:43 PM · edited Mon, 02 August 2010 at 11:43 PM
You could probably shape the teeth with magnets. I'm not saying it would be easy, but it should be possible.
TrekkieGrrrl ( ) posted Mon, 02 August 2010 at 11:44 PM
 You can't do this with a texture, that would require the teeth to be single sided lanes and not actual models. It should be done with a morph.
Since the G2 figures has the same bodies with different heads, any morph should be made for the specific character. Which one is it you're using? I wouldn't mind giving it a try, but I'm on my way home from work now after a full night's work, so I need some sleep first...
sdsullivan ( ) posted Tue, 03 August 2010 at 12:18 AM
> Quote -  You can't do this with a texture, that would require the teeth to be single sided lanes and not actual models. It should be done with a morph. > > Since the G2 figures has the same bodies with different heads, any morph should be made for the specific character. Which one is it you're using? I wouldn't mind giving it a try, but I'm on my way home from work now after a full night's work, so I need some sleep first...
I'm using the Ahava modification for the Olivia figure.
I'm attaching an earlier version of the current render with this character, which doesn't show much tooth.  The next render may show her mouth, and the character -- from the Tournament of Death -- is supposed to have shark teeth.
 Stephen D. Sullivan
wyrwulf ( ) posted Tue, 03 August 2010 at 12:26 AM
Millennium Teeth might work. They are "false teeth" with plenty of morphs. You would have to fit them to your model, though.www.daz3d.com/i/3d-models/-/millennium-teeth
sdsullivan ( ) posted Tue, 03 August 2010 at 12:42 AM
Quote - Millennium Teeth might work. They are "false teeth" with plenty of morphs. You would have to fit them to your model, though.www.daz3d.com/i/3d-models/-/millennium-teeth
That should just be a matter of size & placement, though, right?
And figuring out how to turn off the native teeth.  (G2 seems to have less morphs & options than DAZ figures.)
Seems like a good suggestion, if I can make it work.
Thanks!
(Other suggestions still welcome.)
 Stephen D. Sullivan
wyrwulf ( ) posted Tue, 03 August 2010 at 11:55 AM
Size and placement, then probably parenting to the head. You should be able to make the original teeth transparent in the material room.
WandW ( ) posted Tue, 03 August 2010 at 4:32 PM
Andolaurina's Oktober character for Sydney has fangs.  It's on sale for $1.99 at CP...
sdsullivan ( ) posted Sun, 08 August 2010 at 6:39 PM
 I ended up using the Millennium Teeth from DAZ, which has a nice pointy option.  I used the Stephanie Set (there are a few sets of teeth, all from DAZ1 folk, I think), which seemed a good match for Olivia/Ahava.  Didn't even have to resize them, as it turned out.
A bit tricky placing them in the head, but I had a pose with a slightly open mouth to start.  Then put the teeth in the scene at about the right spot (over Umira's head) using the side view camera.  Then I simply moved them down until I could see them through the open lips, using both the side and front views of the head to adjust them up and down & forward and back, until I got them when I liked them
Then I parented the teeth to the head.
Then I went to the Materials Room and made the material on the original teeth 100% transparent.  Maybe there was a better way to "pull" the original teeth, but that's what I came up with.
The new teeth have their own open & close morph.  So when I open the character's mouth, I have to then go to the teeth figure and open them, too, an appropriate amount.  Again, maybe there's some easier way to do that, but I don't know it.
All in all, it seems to work pretty well, and it achieves the effect I wanted.  (Tip for Writers: One should always be careful when describing a character that one will one day have to illustrate.)  We'll see how it turns out in the final render(s).
Thank you, one and all, for all your great suggestions!
I will put up some pictures of the final results when I'm on the rendering computer later (it's busy rendering now).
 Stephen D. Sullivan
wyrwulf ( ) posted Mon, 09 August 2010 at 12:12 PM
I'm glad it worked out for you. I think that the way you did it was probably about the easiest way.
sdsullivan ( ) posted Mon, 09 August 2010 at 4:39 PM
 Here's the new teeth in action.
You'd yell too if a megalodon were chasing you!
 Stephen D. Sullivan
sdsullivan ( ) posted Mon, 09 August 2010 at 4:42 PM
 And here's a rough of the cover that goes with.
Note that the angle doesn't actually show the teeth much.  But knowing the details are right is what counts.
(Note this is still a work in progress.)
 Stephen D. Sullivan
