Fri, Jan 10, 7:28 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Subject: Dynamic cloth V4 vs M4
argus1000 ( ) posted Mon, 16 August 2010 at 9:51 AM · edited Fri, 10 January 2025 at 1:34 PM
I don't render in Poser but in Carrara. I use Poser a lot, though, for dynamic cloth and the walk designer. I noticed one thing: I never see poke through after running a simulation with V4, but there's lots of poke-through with M4. I would like to use Trekkie Girl's clothes for M4, but it's practically worthless. Is this because V4 is designed differently than M4? And is there a workaround   that  problem?
ShaaraMuse3D ( ) posted Mon, 16 August 2010 at 9:54 AM
 That depends on the clothing, not just the figure..  Is the clothing made for M4 in the first place?
Fugazi1968 ( ) posted Mon, 16 August 2010 at 10:14 AM
If the clothing is made for M4, try raising the collision offset/depth, this can help with poke through on dynamic cloth.
Fugazi (without the aid of a safety net)
https://www.facebook.com/Fugazi3D
argus1000 ( ) posted Mon, 16 August 2010 at 11:14 AM
Yes, Grappo, it was made for M4. But I often use cloth made for other figures and they work for V4. Dynamic cloth is very handy that way.
Thanks, Fugazi, I'll try that! I liked your videos on dynamic cloth on Youtube. They tought me things.
ShaaraMuse3D ( ) posted Mon, 16 August 2010 at 11:24 AM
 If the clothing is modelled so it doesn't have enough vertices around certain areas, pokethroughs are more likely. They happen most often around knees, elbows, breasts and other parts that tend to stick out from the rest.
Can you post a screenshot where you get the pokethroughs, plus an image with a filled wireframe?
Fugazi1968 ( ) posted Mon, 16 August 2010 at 12:23 PM
Quote - Yes, Grappo, it was made for M4. But I often use cloth made for other figures and they work for V4. Dynamic cloth is very handy that way.
No problem :) glad they were of use.
John
TrekkieGrrrl ( ) posted Mon, 16 August 2010 at 7:02 PM
 Hm. What exactly do you have of problems? Believe me, I posed and rendered those clothes quite a lot of times, and never had any pokethru. So I'm really curious as to how you get it and why. I'm assuming you're referring to the free jeans-and-shirt set I made?
argus1000 ( ) posted Tue, 17 August 2010 at 1:19 AM
> Quote - Can you post a screenshot where you get the pokethroughs, plus an image with a filled wireframe?
Here is M4 with morphs (I shortened his legs) walking.   BTW, I like your V4 dynamic clothes the best because you provide many variations of designs, and lots of textures.
argus1000 ( ) posted Tue, 17 August 2010 at 1:21 AM
Here's the wireframe pic. I'm not sure if that's you wanted.
argus1000 ( ) posted Tue, 17 August 2010 at 1:26 AM
Quote -  Hm. What exactly do you have of problems? Believe me, I posed and rendered those clothes quite a lot of times, and never had any pokethru. So I'm really curious as to how you get it and why. I'm assuming you're referring to the free jeans-and-shirt set I made?
Yes, I'm referring to the free jeans-and-shirt set., but I also had poke through problems with other designer's clothes as well, So I don't think your clothes are the problem, although the V4 pajamas that you designed gave me a hard time adjusting them because of the bell bottoms. I had to make elaborate soft-decorated groups to try to control them; they were flying all over the place. But it's all under control now.
Fugazi1968 ( ) posted Tue, 17 August 2010 at 2:02 AM
the bottom of those pants are too low poly, thats a recipe for poke through in dynamic stuff.
In the simulation settings you may get better results using "Object Polygon against cloth polygon".  Alternatives :) Hide his lower leg so ya cant see it :)
John
ShaaraMuse3D ( ) posted Tue, 17 August 2010 at 2:23 AM
 Exactly what Fugazi said. Too few polys to properly match the calves.  His other suggestions are good too. :)
When I work with dynamic clothes that cause pokethroughs like this, I usually work around in two ways:
  1. Import the mesh in Wings and run some smoothing/subdivision on it, if it's really lowpoly, then import it back into Poser and run the simulation. I have a fast computer, so I don't mind the extra calculation, and it will look better.
  2. Work with morphs.  A common case is where there are too few polys around the nipples of V4. If I don't subdivide to accomodate this, I just run the simulation, with the nipples on, and then turn the morph down afterwards. Only problem is to remember to turn it back on..
  3. Morph tool. I had a problem with really long faces on a dress I bought that couldn't drape around a character's knee (similar to what you have on the screenshot)  So what I did was to make some morphs on the clothing with the 'pull' tool. gently, subtly.  Then I could use these morphs to adjust the image.
Morphs and stuff work well if you do still images, but if you're animating, you want to make sure it works fine in every frame. Then subdividing or increasing collision offset a little, or even scaling down the calf in the final animation may be the best idea.
argus1000 ( ) posted Tue, 17 August 2010 at 2:54 AM
Thanks Fugazi and Grappo2000; I'm learning,  I'm learning...
TrekkieGrrrl ( ) posted Tue, 17 August 2010 at 5:59 AM · edited Tue, 17 August 2010 at 5:59 AM
 Hm This is a rather heavily morphed character. How did you apply the morph? During the simulation or what?
The pant legs are a tradeoff between polycount and speed. Of course I could have subdivided them into oblivion (and if it's a problem in general, I will) but I didn't have this problem at all when I tried it myself so I'm seriously puzzled as to why there's this large pokethru.
Did you alter the cloth density? The default gives a rather stiff cloth that doesn't follow the underlying mesh much.
ShaaraMuse3D ( ) posted Tue, 17 August 2010 at 6:01 AM
 Oh yeah, you can experiment a bit with fold resistance too. :)
TrekkieGrrrl ( ) posted Tue, 17 August 2010 at 6:37 AM
 OK.. I just tried and I can't replicate that pokethru issue at all...
I DID set the cloth density to something a little softer, but other than that, I left it as is. Only thing checked is Clothe Self Collision.
So how DID you apply that morph? When I made mine, I had the default M4 (zeroed, since his default pose is a little different from the zeroed pose) on frame 1, and at frame 30 he is fully morphed (Superhero at 1 and Bulk at .. something bulky L) and posed.
He both bulks up AND poses during the simulation. And there's no pokethru anywhere.
TrekkieGrrrl ( ) posted Tue, 17 August 2010 at 6:38 AM
 FFS.. pic was too big... here it is:
argus1000 ( ) posted Tue, 17 August 2010 at 7:27 AM
Quote - So how DID you apply that morph?
I'm doing animation so I apply the morphs before I do the simulation.
argus1000 ( ) posted Tue, 17 August 2010 at 7:59 AM
I am happy to announce that, with a collision offset of .8, I have no poketrough anymore.
TrekkieGrrrl ( ) posted Tue, 17 August 2010 at 7:18 PM
 Hm but you'll have to do the morphs during the simulation, otherwise they'll never fit (or.. well they might but not good) - that doesn't eman you can't still animate, just use the first 20-30 frames to set the morph, THEN start on your animation. doing the morph gradually will allow the clothes to expand and fit the character. And that's not just for my clothes but for all dynamic clothes used on a morphed character :)
Glad you got it solved, but an offset of .08 (if this is inches and not centimeters, I dunno what your Poser units are) seems like quite a bit...
Fugazi1968 ( ) posted Wed, 18 August 2010 at 5:55 AM
Good old Collision Offset, always gets there in the end ;)
