Thu, Feb 6, 8:08 PM CST
Subject: Bryce 5 speed-up tip!
konan ( ) posted Tue, 07 August 2001 at 11:38 AM · edited Thu, 06 February 2025 at 7:58 PM
Attached Link: http://innuendo.ev.ca/NatPose
I noticed that if instead of using Normal anti-aliasing in Bryce 5 (damn slow), that if I used the premium effects with 4 rays per pixel, the rendering time was drastically reduduced (by about 1/3). This pic is a frame from an animation that I am working on using Natural Pose. Using premium effects with 4 rays per pixel, each frame took about 2 minutes to render (Pentium III, 550) while using normal anti-antialiasing it took over 3 minutes.
TomDowd ( ) posted Tue, 07 August 2001 at 1:17 PM
Interesting....and you saw no appreciable difference? TomD
konan ( ) posted Tue, 07 August 2001 at 1:26 PM
The normal anti-aliasing was a little smoother than the 4 rays per pixel thingy, but for animation purposes, it is not significant. I have yet to try a higher rays-pre-pixel setting to see if it is better while still being faster than the normal anti-aliasing. I also notice that rendering at a higher resolution without anti-aliasing can be faster than with it. One could render the pic 50% larger and then resample the image to a smaller size, creating an anti-aliased effect. I will post some images in the near future to see if these techniques are worth it or not. Konan
willf ( ) posted Tue, 07 August 2001 at 10:04 PM
I'ts "worth it" especially for printed pieces. I never use AI as you need to apply the "unsharp" filter in Photoshop anyway to sharpen the image pixels before printing.
jdenoma ( ) posted Thu, 23 August 2001 at 9:13 PM
For animations I've noticed too that changing from Uniform scene to Clustered scene, I cut the per frame time from 20 minutes to just under 3 minutes with no noticeable change in quality of animation. Still learning how to tweak the renders with all the new bells and whistles!
