Thu, Jan 30, 8:06 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 29 10:50 pm)
Subject: The LuxPose Project - Alpha Stage
Khai-J-Bach ( ) posted Mon, 06 September 2010 at 5:20 AM
Quote - This thread is almost done once the beta is out.
we are FAR from a Beta.
estherau ( ) posted Mon, 06 September 2010 at 5:33 AM
 quote:-
"a rey(Poser) render does it 100 times faster? "
I don't think poser does this satisfactorally really.  Also there may be something neat with the lux render engine like angle of incidence shaders (like in vue) or something and a one or two click way of applying.  That's why I asked.
I know lux is designed for reality but I don't know what it is capable of doing and I wondered if tooning was something it might be capable of because it seems to use fairly simple shaders.  I still would not be surprised if someone does hit on something that does this one day with lux.
BTW I do not call a thick black line all the way around an object tooning.  Also I looked at mangastudio and it is not the look I'm after either.
Anyway I got my answer early on when I posted, when someone said there is probably a different render engine that would do it better, and using the ideas they have grasped from exporting to lux they well maybe able to make exporters to other render engines that may be more suitable for tooning.
Love esther
MY ONLINE COMIC IS NOW LIVE
ShawnDriscoll ( ) posted Mon, 06 September 2010 at 5:36 AM
Quote - there is probably a different render engine that would do it better, and using the ideas they have grasped from exporting to lux they well maybe able to make exporters to other render engines that may be more suitable for tooning.
Love esther
That would make sense to do.  I'm always on the lookout for a good toon renderer for different style graphic novel type art.
ice-boy ( ) posted Mon, 06 September 2010 at 5:51 AM
so we had some problems with smoothing on reflective objects right? and glass?
i found an old thead on Luxrender forum about this. its back from may june. yet it looks like the bug is stil there right?
www.luxrender.net/forum/viewtopic.php
adp001 ( ) posted Mon, 06 September 2010 at 6:09 AM
I would like to see Aqsis as the next candidate. Mutch easier to convert Poser materials, because Aqsis is using the same type of material-definition (RenderMan standard).
See http://www.aqsis.org/
But now back to LuxPose :)
nightfall ( ) posted Mon, 06 September 2010 at 7:04 AM
Fryrender, a commercial physically-based unbiased renderer, has a toon render core so it is not impossible for luxrender to have one, although I don't  think the current developers has any interest.
The main difference between biased and unbiased renderers is in the lighting calculation. The material/shader system in luxrender is based on the same models used in biased renderers.
adp001 ( ) posted Mon, 06 September 2010 at 10:21 AM · edited Mon, 06 September 2010 at 10:23 AM
**LuxPose version 1.20
No big changes yet. Light grouping works. To use it, rename your lights like this:
Original Names, : Light 1, Light 2, Light 3
Rename to: GR1:Light 1, GR1: Light 2, GR2:Light 3
In Lux-GUI you will see two lightgroups after export: GR1 and GR2. Now you are able to adjust intensity (gain) and color of each lightgroup individually.
You may use any strings insteed of "GR1", "GR2".  The groupname is the part before ":".
Other additions: Infrastructure to support texturename/texturepath substitution. Needed for network rendering etc. No connection to GUI yet.
ice-boy ( ) posted Mon, 06 September 2010 at 10:46 AM
pciccone who created the Daz exporter for Luxrender wrotte this on the lux forum 1 week ago.
''- Skin material. We have debated the use/faking of SSS but I'm actually thinking of skin material like the other basic materials, glossy, glass etc. The reason is simple, faking it is a lot of work and it's not always working out of the box. The human skin is partially glossy but with a shine that is unique. A skin shader would make life a lot easier and lead to more realistic results.''
this is the answer that he got.
A "true" skin material would require a multilayer BSSRDF (bidirectional surface scattering reflectance distribution) which it a bit involved to introduce. I've seen a couple of approaches in pbrt which typically ends up being implemented as a special case integrator with various preprocess steps. I doubt your users are interested in making the various layers of *dermis maps etc that is needed :) "Ordinary" SSS doesn't work very well for skin either, it usually just makes the models seem like wax or plastic. So perhaps a variant of your "hack" (matte translucent + glossy) combined with a asperity scattering BRDF would be a better approach for this (asperity: see for example http://bit.ly/c0axBU)
I would like to add that your users' use of the "simple hack" brings pretty amazing results already! :)
EDIT: I'm implementing the "The Secret of Velvety Skin" BRDF (paper linked above) in lux just to see how it looks and if its worth having
http://www.luxrender.net/forum/viewtopic.php?f=27&t=4487&hilit=fireflies
is this a joke or what?
Khai-J-Bach ( ) posted Mon, 06 September 2010 at 10:51 AM
why don't you ask them
we're not mind readers...
LaurieA ( ) posted Mon, 06 September 2010 at 10:54 AM
It's not a joke. They just implemented the brdf velvety texture in the lastest Luxrender Linux build. The rest of us will have to wait a little longer ;o).
ice-boy ( ) posted Mon, 06 September 2010 at 11:13 AM
forget about the velety texture.
it makes me angry what kind of opinion Lux users have about the SSS.
ice-boy ( ) posted Mon, 06 September 2010 at 11:16 AM · edited Mon, 06 September 2010 at 11:17 AM
in other news ice-boy is official addicted with glossy reflection. ohhhhh f.... yeah.
curve contrast in photoshop. everything else was done in Luxrender 0.7
LaurieA ( ) posted Mon, 06 September 2010 at 11:17 AM
Quote - forget about the velety texture.
And you're the only one that's been screaming for it. Seems the rest of us are willing to use a workaround. We ARE Poser users after all. We're quite used to workarounds.
The velvety textures will help a lot, and not just with skin. I'm glad they added it. It's a free renderer - you can't have everything you want. Unless you wanna pay for it, that is.
LaurieA ( ) posted Mon, 06 September 2010 at 11:24 AM
Quote - in other news ice-boy is official addicted with glossy reflection. ohhhhh f.... yeah.
Very cool :o). One of Xurge's?
ice-boy ( ) posted Mon, 06 September 2010 at 11:27 AM
Quote - > Quote - in other news ice-boy is official addicted with glossy reflection. ohhhhh f.... yeah.
Cyber suit.
FrankT ( ) posted Mon, 06 September 2010 at 1:08 PM
SSS tends to be computationally expensive (at least on the render engines I've tried it on so far) so if there's a hack which looks good enough then it might be an idea to use it.
Most scenes you probably wouldn't notice the difference on humans
My Freebies
Buy stuff on RedBubble
wolf359 ( ) posted Mon, 06 September 2010 at 2:09 PM
Quote - SSS tends to be computationally expensive (at least on the render engines I've tried it on so far) so if there's a hack which looks good enough then it might be an idea to use it.
Agreed it (SSS) slows Down MODO401, Vray&Maxwell Substantially!!!!.
My website
ksanderson ( ) posted Mon, 06 September 2010 at 2:40 PM · edited Mon, 06 September 2010 at 2:40 PM
I have yet to see SSS that looked right in general on CG characters. The only time it helps is when ears or maybe hands are backlit. But generally you don't even see that in movies or real life. Velvety skin has been missing and all the most realistic CG renders I've seen of humans are softly lit. Looks to me the Lux developers are on a better track. Fryrender has SSS and even a variation which still doesn't look real on characters in their gallery, but does look good on leaves and static objects. But as has been proven over in the Octane Render forum, translucency can work just as well for leaves and some objects.
Kevin
FrankT ( ) posted Mon, 06 September 2010 at 2:46 PM
MentalRay has a fast skin SSS shader but it's a right pig to set up and if you don't get it exactly right, it looks like crap
My Freebies
ShawnDriscoll ( ) posted Mon, 06 September 2010 at 10:58 PM · edited Mon, 06 September 2010 at 11:01 PM
Quote - EDIT: I'm implementing the "The Secret of Velvety Skin" BRDF (paper linked above) in lux just to see how it looks and if its worth having
SSS is great for bars of soap, candle wax, plastic toys.  But for human skin, marble, ruby, even granite there is no way for SSS to achieve realism.  That's where BSSRDF comes in.  Lux and others have the material and lighting thing down.  It's what people are hoping to achieve with Lux and the other renderers is where things begin to fall apart.
ice-boy ( ) posted Tue, 07 September 2010 at 3:29 AM
i promised i will stop talking about this. so thanks.
clayphd ( ) posted Tue, 07 September 2010 at 12:12 PM
YES! I figured out my problem and why LuxRender kept crashing! :thumbupboth: The problem seems to stem from not having enough memory on my laptop (only 2 GB) but I was able to over coming this problem by removing a lot of the references to the same picture over and over again. I had to go LXM file and just have the repeat textures check the first instance of the image and then remove all other references to those images. Once I did that, it stopped crashing on me.
clayphd ( ) posted Tue, 07 September 2010 at 12:50 PM
I think my explanation makes little to no sense of what I did to fix the problem...
Lucifer_The_Dark ( ) posted Tue, 07 September 2010 at 1:03 PM
I only have 2Gb on my machine too, the problem is any renderer has to load the textures it's going to use into memory, if you're asking it to load "300" copies of the same thing & that uses up all the memory it'll crash.
What were you trying to render?
Windows 7 64Bit
Poser Pro 2010 SR1
clayphd ( ) posted Tue, 07 September 2010 at 1:08 PM
It wasn't much, I don't think... M4, Shorts from Casual Wear, Glynn hair, and forest from Multiplane Cyclorama. Most of the corrections I had to do was with M4
Lucifer_The_Dark ( ) posted Tue, 07 September 2010 at 1:19 PM
I haven't seen anyone else mention a problem like that with M4, but then I'm not sure if anyone else is actually using him with LuxRender, this might even be a bug in LuxPose that the guys haven't seen yet.
Windows 7 64Bit
Poser Pro 2010 SR1
MyCat ( ) posted Tue, 07 September 2010 at 3:00 PM
Quote - ...if you're asking it to load "300" copies of the same thing & that uses up all the memory it'll crash.
IMHO any render engine that fails to notice that a texture mentioned in 10 different skin shaders is the same file, and thus ends up loading ten copies of the decompressed texture into memory, is broken.
adp001 ( ) posted Tue, 07 September 2010 at 3:02 PM
Quote - > Quote - ...if you're asking it to load "300" copies of the same thing & that uses up all the memory it'll crash.
Lux does not load the same texture more than once. Look into Lux-log to see which images are just referenced while loading.
clayphd ( ) posted Tue, 07 September 2010 at 3:03 PM
 I did, that is how I found the problem, that and having task manager open to watch how much ram was being used.
Dead_Reckoning ( ) posted Tue, 07 September 2010 at 3:14 PM
I may have written this down already, but I cannot find it today.
Question: When editing the LuxRender Material, "lxm File", beside "glossy", what other choices do I have?
TKS
"That government is best which governs the least, because its people discipline themselves."
Thomas Jefferson
clayphd ( ) posted Tue, 07 September 2010 at 3:50 PM
 Maybe I am wrong... all I know is that my computer does not seem to like all of the
Image_Map_3
Texture "ImageMap_85" "float" "imagemap"
"string filename" ["C:UsersClayDocumentsDaz 3DStudio3ContentRuntimetexturesMorrisHiro4JMHiroLimbB.jpg"]
"float vscale" [-1.0]
"float uscale" [1.0]
"float gamma" [1]
over and over again with the only difference really being the number attached to the "ImageMap_
and when I get rid of all those and make others point to first ImageMap_85 with the file attached it works, when I leave all the others in it crashes... and now that isn't the only one that does it for, just an example of one of the images that comes up over and over again in the lxm file.
ShawnDriscoll ( ) posted Tue, 07 September 2010 at 4:21 PM · edited Tue, 07 September 2010 at 4:23 PM
You must be talking about some of Vue Infinite's latest updates.  Out Of Memory errors just for importing a Poser figure (that happens to have the same texture map for every knuckle on every hand on every arm).  Madness.
Flenser ( ) posted Tue, 07 September 2010 at 4:28 PM
Quote - I may have written this down already, but I cannot find it today.
TKS
The other choices so far, are  - carpaint
  • glass
  • glossy
  • matte (default)
  • mattetranslucent
  • metal
  • mirror
  • mix
  • null
  • roughglass
  • shinymetal
You'll find all the possible choices and their parameters on the Luxrender wiki, http://www.luxrender.net/wiki/index.php?title=Scene_file_format#Materials
Software: OS X 10.8 - Poser Pro 2012 SR2 - Luxrender 1.0RC3 - Pose2Lux
Hardware: iMac - 3.06 GHz Core2Duo - 12 GB RAM - ATI Radeon HD 4670 - 256 MB
adp001 ( ) posted Tue, 07 September 2010 at 4:58 PM
Quote -  Maybe I am wrong... all I know is that my computer does not seem to like all of the
Image_Map_3
"float gamma" [1]
Lux is using FreeImage to deal with images. Maybe your images are "not compatible" with this? Hm. Poser uses Freeimage also. But anyway: Try to open one of the problematic images with an Image-Editor and save it again.
Or is the imagepath a "virtual path"? I have had some trouble with network pathes. Sometimes it worked, sometimes not.
Dead_Reckoning ( ) posted Tue, 07 September 2010 at 4:59 PM
Quote - The other choices so far, are  - carpaint
  • glass
  • glossy
  • matte (default)
  • mattetranslucent
  • metal
  • mirror
  • mix
  • null
  • roughglass
  • shinymetal
Thanks
Link saved to favorites and information Copied and pasted to a Saved File.
Thomas Jefferson
adp001 ( ) posted Tue, 07 September 2010 at 5:01 PM · edited Tue, 07 September 2010 at 5:02 PM
Another idea: Is Lux able to access the images? Often Poser and DS are installed as administrator. So the administrator owns all images. Maybe a standard user (Lux) are not allowed to access them ...
adp001 ( ) posted Tue, 07 September 2010 at 5:04 PM
Nobody with new images here?
Show us your tests!
Dead_Reckoning ( ) posted Tue, 07 September 2010 at 5:33 PM
Quote - Nobody with new images here?
Show us your tests!
Rendering now.
Thomas Jefferson
FSMCDesigns ( ) posted Tue, 07 September 2010 at 5:51 PM
Show us your tests!
Gladly, but how do you attach an image to a post and what size/properties?
Regards, Michael
My DeviantArt page
adp001 ( ) posted Tue, 07 September 2010 at 6:04 PM
Quote - > Quote - Nobody with new images here?
Show us your tests!
I use often 800 in X (use JPG images to save space).
Below the input field (where you type your message) you read: "Attach a file" and a button to select your image. Do this and - to be sure - click "Preview Reply". You should see your image then.
Flenser ( ) posted Tue, 07 September 2010 at 6:05 PM
Show us your tests!
I put mine in my gallery, http://www.renderosity.com/mod/gallery/browse.php?user_id=627255
And I've currently got a test rendering at home of the close-up portrait I posted 2 days ago, this time with skin material changed to mattetranslucent.. not sure how that's gonna look, it looked a bit strange in the first 5 minutes before leaving for work. :p
Jcleaver ( ) posted Tue, 07 September 2010 at 6:13 PM · edited Tue, 07 September 2010 at 6:14 PM
Attached Link: There Will Be Grease
I'll post one when it finishes baking.  May be a while.  Meanwhile see link to one in my gallery.
Flenser ( ) posted Tue, 07 September 2010 at 6:51 PM · edited Tue, 07 September 2010 at 7:01 PM
Quote - I'll post one when it finishes baking.  May be a while.  Meanwhile see link to one in my gallery.
The buildings and street look wonderful in that render, the machinery in the foreground looks too clinical though and the sky doesn't show any gradient or variation.
It would be a good scene to experiment with the sunsky parameters.
Have a look at the abstract of a research document on the Perez Sky Model. I'm guessing the parameters a-e in this text are connected to the aconst-econst parameters in the sunsky light.
======== Abstract
Perez et al. developed a five parameter model to describe the sky luminance distribution [24]. Each parameter has a specific physical effect on the sky distribution. The parameters relate to (a) darkening or brightening of the horizon, (b) luminance gradient near the horizon, (c) relative intensity of the circumsolar region, (d) width of the circumsolar region and (e) relative backscattered light.
========= example sunsky
If you want really blue skies, try this:
AttributeBegin
LightSource "sunsky" "integer nsamples" [1]
            "vector sundir" [0.70000 0.400000 0.700000]
        "color L" [1.000000 1.000000 1.000000]
        "float turbidity" [2.000000]
        "float aconst" [0.500000] "float bconst" [0.500000] "float cconst" [1.000000] "float dconst" [1.000000] "float econst" [1.000000]
        "float relsize" [2.000000]
AttributeEnd
odf ( ) posted Tue, 07 September 2010 at 6:56 PM
Image_Map_3
"float gamma" [1]
Like ADP said, Lux claims to be reusing image memory when it comes across the same image more than once. But it's possible that it stores an extra pre-processed copy for each texture that image is used in. It would then be up to the exporter to optimize what's in the lxm file.
Unfortunately, that's bagginsbill's department, and we haven't heard much from him lately. Even if he's aware of this problem, it might not be too high on his agenda, as there is still so much else to be taken care of. Maybe someone should add it to the wishlist?
Jcleaver ( ) posted Tue, 07 September 2010 at 7:24 PM
Quote - > Quote - I'll post one when it finishes baking.  May be a while.  Meanwhile see link to one in my gallery.
======== Abstract
AttributeBegin
AttributeEnd
Those settings shown here are the settings I used for the scene.  This was my first test scene, so I wasn't as picky about content, as I was about how it would work.  The one I'm rendering now is a V4 character and the subdragon.  No special posing, just testing how the exporter is handling the textures.
Jcleaver ( ) posted Tue, 07 September 2010 at 8:48 PM
OK.  Simple pics just for testing materials.  First one is Poser Final render, and the second is LuxRender, from LuxPose.
Jcleaver ( ) posted Tue, 07 September 2010 at 8:49 PM · edited Tue, 07 September 2010 at 8:51 PM
OK, here is the second from LuxRender:
The only thing I can come away with is I am not sure that I will be using Firefly very much anymore!
Dead_Reckoning ( ) posted Tue, 07 September 2010 at 9:17 PM · edited Tue, 07 September 2010 at 9:19 PM
Poser 8 using Exporter 1.2. LuxRender with 0925 Update. M4 with one Point light and one Spot light. Basically turned them off and used the SunSky.
4 hours and 2170 S/px
Thomas Jefferson
adp001 ( ) posted Tue, 07 September 2010 at 10:09 PM
If I use the sunsky from above, my log says:
[2010-09-08 05:08:42 Warning: 0] Parameter 'aconst' not used
[2010-09-08 05:08:42 Warning: 0] Parameter 'bconst' not used
[2010-09-08 05:08:42 Warning: 0] Parameter 'cconst' not used
[2010-09-08 05:08:42 Warning: 0] Parameter 'dconst' not used
[2010-09-08 05:08:42 Warning: 0] Parameter 'econst' not used
[2010-09-08 05:08:42 Warning: 0] Parameter 'L' not used
Flenser ( ) posted Tue, 07 September 2010 at 10:24 PM
That's strange, how about if you use sun instead of sunsky?
