Thu, Nov 21, 7:40 PM CST
Subject: Good free video editing software ???
RorrKonn ( ) posted Mon, 06 September 2010 at 6:51 AM · edited Thu, 21 November 2024 at 7:31 PM
Need video editing software.
Can afford ah ,free editing software. ;)
So what is some good free editing software do you all use ?
Thanks
saibabameuk ( ) posted Mon, 06 September 2010 at 8:15 AM
 You can download Final Cut Express as a free trial, It is superb addition to Poser .
santolina-sailor ( ) posted Mon, 06 September 2010 at 8:38 AM
Have a look in here loads of stuff and check out if the  the file formats you are using is available in your choice,depends a lot on what you are editing.[
http://tv.isg.si/site/?q=node/873](http://tv.isg.si/site/?q=node/873)
p
thefixer ( ) posted Mon, 06 September 2010 at 1:30 PM
I use windows movie maker..sad but true...
Does what I need.... LOL!
Injustice will be avenged.
Cofiwch Dryweryn.
nakamuram ( ) posted Mon, 06 September 2010 at 1:42 PM
Try Avidemux -- http://www.avidemux.org or Video Edit Master http://software.tutorialsroom.com.  Both are freeware, not shareware demos.
Kenmac ( ) posted Mon, 06 September 2010 at 4:26 PM
One free video editor that tends to be overlooked is Pinnacle Videospin. Here's the URL: http://www.videospin.com/redesign/default.asp
lmckenzie ( ) posted Mon, 06 September 2010 at 5:09 PM
Attached Link: Virtualdub
I got Avid Xpress before they discontinued it some years ago but I've never used it. VirtualDub is a nice, widely used application - depending on your needs There are quite a filters available to enhance it. Between it and AVIDemux, my rather basic needs are met pretty well.
"I use windows movie maker..sad but true..."
Actually, I've read a lot of good comments on Movie Maker, and almost none of the trashing that usually goes with any Microsoft product. Apparently starting with the version included with either Vista or Seven though they changed it and it supposedly has somewhat fewer features though.
santolina-sailor ( ) posted Tue, 07 September 2010 at 5:53 AM
Never did get any decent results with Movie maker,lost lots of detail and contrast when using AVIs,by the way Win 7 no longer carries Movie maker.
p
imagination304 ( ) posted Tue, 07 September 2010 at 6:37 AM
(bookmarked)
lmckenzie ( ) posted Tue, 07 September 2010 at 6:58 AM
Attached Link: Movie Maker 2.6
They changed the name and broke it out:
"Windows Live Movie Maker is part of Windows Live Essentials and might already be installed on your computer. To see if Windows Live Movie Maker is already installed, click the Start button , type Windows Live Movie Maker, and see if it appears in the list of results. If it doesn't, you can download and install it for free from the Windows Live Movie Maker website."
You can also download an updated version of the original (v. 2.6) for Vista and (supposedly) Seven, if you want the extra functionality they removed from the "Live" version.
I wouldn't be surprised if it's wmv-centric :-)
santolina-sailor ( ) posted Tue, 07 September 2010 at 12:02 PM
Thanks ,sure its for Windows 7?
p
flyerx ( ) posted Tue, 07 September 2010 at 9:23 PM
Attached Link: http://www.papajohn.org/MM2-SavingMovies-CustomProfiles.html
If you want to use Windows Movie Maker I would recommend the attached link for optimal settings to create quality movies.
Windows Movie Maker: (Windows XP, Vista & 7)
http://www.microsoft.com/windowsxp/downloads/updates/moviemaker2.mspx
There is the new Windows Live Movie Maker but it does not have as many features as the older version.  Besides if you are using XP SP2 or later it should be already installed.
If you want to create DVDs from the movies that you create then I would suggest DVDStyler. (http://www.dvdstyler.de/).
FlyerX
santolina-sailor ( ) posted Wed, 08 September 2010 at 7:10 AM
OK and thanks for the links.
p
LostinSpaceman ( ) posted Wed, 08 September 2010 at 9:24 AM
Attached Link: http://www.avs4you.com/AVS-Video-Converter.aspx
I use AVS4You. It's a complete suite of audio, Video and CD/DVD burning apps! I dropped that resource hawg Roxio for this suite!
aRtBee ( ) posted Thu, 09 September 2010 at 10:06 AM
I use windows MovieMaker, for cutting large videos, and to combine small animation footages with music. It outputs to wvm in some standard sizes, and works well. Avi's are uncompressed, a real nightmare.
Pinnacle Videospin is second, as it can handle other formats. I just found it, so it might promote to #1.
Wax, from http://www.debugmode.com/ , comes third at this moment. It handles multiple videotracks, I just haven't used it that much yet. Looks great though, and can run as a plugin too. Deals with Avi.
Go http://www.prvsoft.com/ for great converters and other free tools, love them.
have fun.
RichardCoffey ( ) posted Fri, 10 September 2010 at 2:11 PM
For my Poser animations, I export with Movie Settings > Format: Image File in PNG format, then import them into Adobe Premiere Essentials using its Import > Numbered Stills checkbox function.
However, Premiere's WMV export function has mysteriously stopped working for me, so I'm now looking for alternatives too. Any further recommendations with the "Numbered Stills Import" requirement in mind?
Thanks,
Richard
