Mon, Jan 27, 8:10 AM CST
Subject: How to change Poser's Focus Guide?
wolfie ( ) posted Sun, 19 September 2010 at 2:55 PM · edited Mon, 27 January 2025 at 7:53 AM
Does anyone know how to change the focus "X" thing in poser 7 and 2010?  I want to add vertical and horizontal lines to it as rarely do the diagonal lines hit what I want them to.
TIA
Wolfie
lesbentley ( ) posted Sun, 19 September 2010 at 8:11 PM
file_459376.TXT
The above file might be a solution. I only just made it this minute, so haven't had time to test it thoroughly yet, but on first sight it seems to be working as expected in P6. I suspect it will work in later versions as well.
Just a cross-hair prop, smart-parented to the FocusDistanceControl. The prop is locked by default to stop it being accidentally moved out of alignment, but can be unlocked if you want to scale it up or down. Changing its Element Display style can give some variation in the thickness and colour of the lines, the Foreground Color can also have an effect in some display styles. The props material is set to transparent, so it should not show up in a render, or just hide it if you no longer want to see it.
Save it to any props pallet, and loose the ".TXT" part of the file extension.
ockham ( ) posted Sun, 19 September 2010 at 8:17 PM
file_459379.txt
Here's a modified OBJ for the focus thing, with X and Y axes added. (Basically I just duplicated the original and turned it 45 degrees.)
Download the attached ZIP, extract camtarget.obj
Find your original camtarget.obj under runtimegeometriescamera.
Save the original under a different name and copy this file in its place.
My python page
My ShareCG freebies
wolfie ( ) posted Sun, 19 September 2010 at 8:34 PM
Thanks you two.  I will give them a run and see which I like better.  Appreciate it!
ockham ( ) posted Sun, 19 September 2010 at 8:38 PM · edited Sun, 19 September 2010 at 8:40 PM
Seems like these things always involve an amazing crosspost.
Les and I both hit Reply within six minutes of each other, six HOURS
after the original.
(I didn't know Les had replied, because I left the OP open in the browser
while I rigged up the object file.)
My python page
My ShareCG freebies
lesbentley ( ) posted Sun, 19 September 2010 at 9:29 PM
Seems that ockham and I often end up tackling the same problems, though usually by different methods, usually Python script for ockham, Poser script for me. Mirroring magnets, and making a camera track a moving figure are just two examples.
wolfie ( ) posted Tue, 21 September 2010 at 9:11 AM
This is a perfect example where two minds, with the same goal, come up with the solution in completely different ways.
I replaced the internal OBJ with the one posted here.  I also put in the prop.  I will likely alter the prop and change it from the + to a series of concentric rings so I can add them with a simple prop when I need them.
I don't always center the camera and aim it at exactly what I want in focus so the "X" frequently doesn't intersect the figure or prop I want in focus.  My solution is to use the old DOF calc script.  Its a pita at times but it works for most applications.  It too has its limitations as it calculates the closest piece of an object but frequently that isn't the focal point.  Example?  The Nose.  From many angles the chin or forehead may be closer, not the nose (rough center of the face).
I do thank you both for brilliantly different methods and because you two came up with different solutions, I have a combination I can play with and expand with additional rings or other angles of lines.
msg24_7 ( ) posted Tue, 21 September 2010 at 3:57 PM
Another solution is using Poser's port setup... I am going to render view through the main cam, switch to 4 port view and adjust focus distance for main cam. You'll see the guide in all 4 views and can really find almost any point within your scene...
Yesterday's the past, tomorrow's the future, but today is a gift. That's why it's called the present.
lesbentley ( ) posted Wed, 22 September 2010 at 8:42 AM
Yes, that's a very good point that msg24_7 makes. In fact I did have to split the view when testing the smart prop, to make sure it was parenting in the correct position.
