Thu, Nov 28, 6:03 PM CST
Subject: Malfuctioning Clothes Morphs...
dmdf11 ( ) posted Sat, 02 October 2010 at 1:52 PM · edited Tue, 19 November 2024 at 3:19 PM
This has been bothering me for awhile and I can't take it any more...I will download clothing, either purchased or found free and conform it to the corresponding model, only to find that most of or all of the FBMs do not work.  I spin the dials and nothing happens.  What's really annoying is that on some clothing, 1 or 2 dials will work and the rest don't.  Not only does this happen on FBMs,  I have had problems with dials on individual parts not work also.  Any ideas?
Medzinatar ( ) posted Sat, 02 October 2010 at 2:37 PM
My first guess is that you have improperly configured installation.
Some clothing come with library folder containing the deltas.  If you for some reason put this in "Program Files..." or some other location that windows wants to "protect" you from using, the folder will be blank and real data is somewhere else.
Maybe you tell us something about your OS and config?
Jules53757 ( ) posted Sat, 02 October 2010 at 3:16 PM
Or the clothes are "superconformin" means, the dials are not really necessary, they follow the dials of the figure. Try to load the dress without the figure and try to use the dials.
Ulli
RobynsVeil ( ) posted Sat, 02 October 2010 at 5:47 PM
Hmmm, I've had that experience as well. The "super-conforming" thing might answer some of that, but that sometimes isn't a solution.
Let's say the dress is a C-cup and your figure is a D. You're trying to get the mesh around the neckline a bit closer to the figure's skin. So, you dial the clothing breast -size management thingies but nothing happens (you're doing this for Body first - nothing happens - and then for Chest). So you select V4 and start twiddling her corresponding dials and the clothing follows her re-sizing, and you end up with ill-fitting clothing.
What to do?
Metaphor of Chooks
Medzinatar ( ) posted Sat, 02 October 2010 at 6:00 PM
Although I have heard the term "super-conforming", I do not know if I actually have any such items.
I understand that if you resave such an item back to library (different name no to overwrite), the new version will not be "super-conforming"
dmdf11 ( ) posted Sun, 03 October 2010 at 9:09 AM
Thanks for the help ....I a running on a Dell FPS 430, 64 Bit Quad Processor with Windows Vista.  My system has a nasty habit of creating compatability files for everything I create, even within the program (Poser) itself...If I create a category of poses in the side window of Poser let's say, my computer files it under Poser Pro, Compatibility Files, Runtime, Library, Poses....so I have 2 runtime folders.  I don't know if that is the problem.  When I unzip content though,  it seems to go into the correct files.
hborre ( ) posted Sun, 03 October 2010 at 1:41 PM
Then it sounds like UAC interfering with Poser installed to the Program Files Folder.  It will only get messier if you continue adding content under this manner.  The corrective action would be either disabling UAC (not really recommended unless you absolutely know your way around the computer) or permanently relocating Poser outside Program Files in it's own folder.
Zev0 ( ) posted Tue, 05 October 2010 at 5:02 AM
Zev0 ( ) posted Tue, 05 October 2010 at 5:18 AM
 or you can do the following.
  1. conform clothes to figure.
    2.select v4 - make sure you are on "body" morph then go to file and go "copy"
    3 select clothing item - make sure you're on "body" morph and go "paste"
That usually copies the figure data to the clothes so they match. This works for most clothing. Some clothes lack certain morphs..
I use Morphing clothes from Dimension3d (http://www.renderosity.com/mod/bcs/index.php?ViewProduct=64629) for when the clothes lack certain morphs that my figure has. Basically I just copy the figure morphs to the cloths and when I go copy paste in poser I get a perfect fit all the time regardless how customized my figure is.
My Renderosity Store
