Thu, Feb 20, 1:26 PM CST
Forum Moderators: RedPhantom
Subject: shimmering skin
RedPhantom ( ) posted Tue, 19 October 2010 at 6:34 PM · edited Tue, 18 February 2025 at 4:17 PM
Site Admin Online Now!
Attached Link: http://bridalclarity.com/images/uploads/makeup13.jpg
 is there a way to make a shader that will make skin shimmer? Like the shimmering powder only all over.
kind of like her eye make up but for the whole body and I can use any skin texture. This is for a race of beings and I'll need it for more than one model. of course being able to adjust the amount of shimmering so it can vary from person to person would be cool.
I hope I'm asking this clearly. I'm not sure I am.
Thanks for any help
RobynsVeil ( ) posted Tue, 19 October 2010 at 6:49 PM
Depending on which skin shader you're using, you can adjust the PoserSurface.specular_value up for all of the skin areas, or whatever is managing that in the shader.
Metaphor of Chooks
Winterclaw ( ) posted Tue, 19 October 2010 at 7:27 PM · edited Tue, 19 October 2010 at 7:28 PM
Noise or spot node in the alt specular channel perhaps?
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
Anthanasius ( ) posted Wed, 20 October 2010 at 5:04 AM
VSS !
Here are the tweaks, may be you can improve this ;)
Génération mobiles Le Forum / Le Site
RobynsVeil ( ) posted Wed, 20 October 2010 at 7:15 AM
Anthanasius has an infinitely more elegant solution than my suggestion: I'd be following that. You can't beat the skin shader that comes with VSS for versatility and flexibility.
Metaphor of Chooks
modus0 ( ) posted Wed, 20 October 2010 at 8:54 AM
Hmmm, desaturate that and you could have the skin of a Soong-type android...
________________________________________________________________
If you're joking that's just cruel, but if you're being sarcastic, that's even worse.
RedPhantom ( ) posted Thu, 21 October 2010 at 7:51 PM
Anthanasius could you please post a screen shot of the right side of that. I'm having trouble telling where to connect things?
bagginsbill ( ) posted Thu, 21 October 2010 at 10:35 PM · edited Thu, 21 October 2010 at 10:39 PM
There are something like 90 nodes there. You don't connect anything. That is my standard PR3 skin shader with no AO. Anth was showing what settings to use. Usually you only mess with the ones on the far left. But to get the gold shimmer, you want to change the color of the Blinn node so that was shown.
It's because the effect was produced with a metallic makeup. Metals produce colored specular reflections. Skin does not. So the skin shader usually has white in the specular color.
By the way, Anthanasius, thanks for posting it. I tried to do better than you did (before you posted) and failed. Being super busy with work, I was not able to continue experimenting. Your post was very much what I had come up with.
I think better is possible, but not without a completely different shader. And maybe it would even need some nodes we don't have in Poser.
While there are quite a few things we can do with the nodes we have, there are some effects that just cannot be assembled from those. The way light is reflected in this case is too different from all of the lighting nodes we have to produce a good match.
bagginsbill ( ) posted Thu, 21 October 2010 at 10:41 PM
The real problem with recreating that photo is that Poser doesn't have area lights. We sort of can have them with IDL, but it only affects diffuse reflection. Since the shimmer is all specular, we can't make it work in Poser. The highlights come out too small.
RedPhantom ( ) posted Sat, 23 October 2010 at 10:58 AM
Just my luck. I have to pick the thing that can't be done for my picture. Maybe the vss shader can be used for now.
Thanks everyone
