Fri, Nov 22, 2:17 PM CST
DAZ|Studio F.A.Q (Last Updated: 2024 Nov 21 11:14 pm)
Subject: Daz Figure setup tools
angiexx2 ( ) posted Tue, 26 October 2010 at 8:49 AM · edited Fri, 30 August 2024 at 7:18 AM
Am stuck at renaming in the figure setup tools
I followed a tutorial by tokejr brilliant thank you for the link :) its worked for me, but when I right click and edit name it doesnt change the same with the label that wont change either am not sure what am not doing
Thanks
Angie
tokejr ( ) posted Tue, 26 October 2010 at 9:01 AM
Yeah, that's really tricky.........can you just put your mouse in the field and highlight it, then hit delete?  Then just type in the name you want.
You could always just change the CR2 manually with a text editor, but that's adding an unnecessary step.
angiexx2 ( ) posted Tue, 26 October 2010 at 9:04 AM
Will try that in a sec see if works
angiexx2 ( ) posted Tue, 26 October 2010 at 9:07 AM
Nope its not letting me do that either
whats the next best thing to do?
if I export it can I change the name of the file or is there more in the file to change that way ?
tokejr ( ) posted Tue, 26 October 2010 at 9:15 AM
No, you can't do that.  I just tested to see and you're going to get an error and it won't create the correct file.  You are going to have to figure out how to rename those fields while in Skeleton Setup.
angiexx2 ( ) posted Tue, 26 October 2010 at 10:08 AM
OK will have a think and a mooch and thank you
angiexx2 ( ) posted Tue, 26 October 2010 at 12:26 PM
Still cant figure out how to change the names have asked in Daz forums aswell, have  uninstalled and installed daz
it changes it but soon as click away from it, it puts it back to its original name
tokejr ( ) posted Tue, 26 October 2010 at 12:32 PM
Quote - Still cant figure out how to change the names have asked in Daz forums aswell, have  uninstalled and installed daz
Oh!  I wish you had said this sooner: it changes it but soon as click away from it, it puts it back to its original name
You just have to hit the ENTER key before you click out of the field.*
angiexx2 ( ) posted Tue, 26 October 2010 at 12:34 PM
rofl okies will go give that a try
I new it was something I was doing or rather not doing lol
thank you
tokejr ( ) posted Tue, 26 October 2010 at 12:41 PM
ROFL, just another one of those forehead slapping moments.  In case you hadn't figured it out, there's a lot of those in rigging.
angiexx2 ( ) posted Tue, 26 October 2010 at 1:05 PM
lol looks like it
well that worked and it does move with v4.2 but theres alot of poke through on the abdomen
which is a big chunk of the top and cannot get it to move using bend etc lol
so that to figure out now lol
Do I need to leave hip in on the rigging as its not on my top as the top ends at the waste
but v4.2s hierachy starts with hip ?
tokejr ( ) posted Tue, 26 October 2010 at 1:15 PM
Yes, the hip must stay.  You did take out the geometry though, correct?
Open the Hip tab by clicking on the arrow next to it.
Right click on Geometry
Click Remove Geometry Reference
Do the same for Alternate Geometry.  (Not sure this is required, but I do it anyway)
This will leave in the Geometry Reference, but remove the actual geometry.
angiexx2 ( ) posted Tue, 26 October 2010 at 1:17 PM
okies will try that thank you :)
tokejr ( ) posted Tue, 26 October 2010 at 1:32 PM
You're welcome
angiexx2 ( ) posted Tue, 26 October 2010 at 6:13 PM
Well no poke through now thank you for all the help
just need to get bend in on the top now lol
then can make the skirt
cschell ( ) posted Mon, 01 November 2010 at 3:36 PM
there's a tut i wrote also on doing conforming items with Daz'z figure set-up tools further down this forum... might have some usefull info for you as well... not sure if it'll help but there it is anyways...
angiexx2 ( ) posted Mon, 01 November 2010 at 4:22 PM
Thank you will take a look at that aswell :)
cschell ( ) posted Mon, 01 November 2010 at 4:44 PM
yw angie :)
