Thu, Feb 13, 8:25 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 7:49 pm)
Subject: how do you stop braids from intersecting a figure?
mikegg ( ) posted Wed, 27 October 2010 at 10:20 PM · edited Thu, 13 February 2025 at 8:25 PM
I'm sure this has been discussed before but I'm not sure what to search for. Can someone help?
So I have V4 with a conforming hair figure that has braids. I'm using PP2010. When I pose v4 the braids intersect the figure even though the hair moves correctly with the head.  I tried turning on collisons for the hair and v4 and made a key frame for the new pose but that doesn't help. Are collisions only for animation? What do collisons actually do and how do you use them?
There are magnets for the braids so I can manually move the braids out from inside the v4 figure, but it seems to me there should be a simple way by now for Poser to understand collisions and intersections.
 I guess this happens with arms and legs too. Is there no simple way to fix this? it's troublesome and I guess I just expect poser figures to have volume or something so one wouldn't have to jump through hoops to fix this and similar issues.
Am I missing something really obvious? Any suggestions on how to address this issue or where to go for help?
I'm sorry if I sound too strident, I'm slightly frustrated. Otherwise I love Poser.
Thanks Mike
kyhighlander59 ( ) posted Wed, 27 October 2010 at 10:25 PM
are the braids morphed or jointed so that you can articulate them? If not you may have to create a morph.
mikegg ( ) posted Wed, 27 October 2010 at 10:54 PM
I'm pretty sure they have morphs...I'll check. How does that affect the issue?
 Acutally the braids have individual parameters and the whole hair has morph fits for different characters.  Each braid has it's own parameter, that's why the magnets are there, so that you can move a group of braids on one side. I tried checking include morphs when conforming, but that didn't seem to help.
Mike
mikegg ( ) posted Wed, 27 October 2010 at 10:57 PM
I forgot to mention that there are 4 individual braids on each side, not just one big braid on each side and some behind the head as well.
Mike
SamTherapy ( ) posted Wed, 27 October 2010 at 11:42 PM
Unless something has changed dramatically, posing hair has always been a matter of trial and error.
hborre ( ) posted Thu, 28 October 2010 at 6:01 AM
Online Now!
Collisions, in this case, will only detect the presence of mesh in contact with each other and will not respond realistically as you would expect to see using animation in the cloth room.  The realism will only occur with dynamic hair, not transmapped hair.  To simulate strand behavior, you will need to use whatever morphing capability that comes with the hair figure and pose the braids in whatever position you desire.
bagoas ( ) posted Thu, 28 October 2010 at 11:22 AM
... or use a magnet.
lkendall ( ) posted Thu, 28 October 2010 at 11:58 AM
Total Hair CTRL
http://market.renderosity.com/mod/bcs/index.php?ViewProduct=69913
This seems to add handles to hair so that it can be posed more easily. It gets good reviews.
LMK
Probably edited for spelling, grammer, punctuation, or typos.
mikegg ( ) posted Thu, 28 October 2010 at 2:46 PM
Thanks to everyone for their suggestions. I like the hair control idea. The current hair has magnets but they're tricky to use.
My problems seems to be a generic Poser problem. There is another recent discussion about dynamic clothes that seems to reflect a similar problem;ie poser meshes are not aware of each other. Even dynamic clothes have problems with the poser figure mesh. Arms and legs also are not "aware" of each other.
In my naive mind, I would like the poser meshes/figures to be solid objects that are aware of each other and would therfore know when another object "bumps" into them. I guess there are a ton of 3d calculations to make this come true.  Maybe in a future version? I think zbrush has solid 3d objects and when you move a zsphere it will not penetrate another zsphere.
So I pose the figure and then fix the hair...That'sthe way to solve the intersecting problem. Every time the pose changes, the hair may have to be changed too. I was hoping for an easier, generic solution. No big deal, one more thing to play with.
Mike
hborre ( ) posted Thu, 28 October 2010 at 3:42 PM
Online Now!
The major problem with the collision feature in the Pose room is that it becomes very memory intensive.  Poser becomes very sluggish after a time.
bagoas ( ) posted Thu, 28 October 2010 at 3:45 PM · edited Thu, 28 October 2010 at 3:47 PM
Quote - In my naive mind, I would like the poser meshes/figures to be solid objects that are aware of each other and would therfore know when another object "bumps" into them. I guess there are a ton of 3d calculations to make this come true.  Maybe in a future version? I think zbrush has solid 3d objects and when you move a zsphere it will not penetrate another zsphere.
Indeed this would blow your circuits. Spheres are easy, of course, in a vectorized world. Poser does use grid definitions and can have collision possibilites, and with PoserPhysics you can do even more. But that is still collisions between (bounding boxes of) objects, and not on mesh level.
You may try to clothify the lower part of the hair and use the cloth room. Strand hair can do collisions, but it is very slow due to the many polygons. You may consider a 'proxy', that is a very rough mesh conforming figure that you use as collision object for the hair. Make it invisible before render.
B.
Dave-So ( ) posted Fri, 29 October 2010 at 8:14 PM
i am now just rendering bald women. Takes all that hair tweaking out of the equation.
I have THC ... its magnets, but a little better behaving than normal magnets. I still find that it doesn;t always bend or move things where you need them to.
Humankind has not woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound together.
All things connect......Chief Seattle, 1854
estherau ( ) posted Sun, 31 October 2010 at 7:02 AM
do u draw the hair in afterwards Daveso?
MY ONLINE COMIC IS NOW LIVE
Dave-So ( ) posted Sun, 31 October 2010 at 8:11 AM · edited Sun, 31 October 2010 at 8:12 AM
Quote - do u draw the hair in afterwards Daveso?
Actually I do quite often . Remove sticking through areas, add where needed. my painting skills are not good though, so it doesn;t always look quite right...its sometimes difficult to get the correct shading on the skin, etc.
editied to add: I sometimes render another pass without the hair and layer that in.
estherau ( ) posted Sun, 31 October 2010 at 8:17 AM
ah so you do render hair then! (if you render a layer without then you render a layer with too)
hehe I knew it.
Love esther
Dave-So ( ) posted Sun, 31 October 2010 at 8:24 AM
Quote - ah so you do render hair then! (if you render a layer without then you render a layer with too)
hehe I knew it.
Love esther
Well, when I was rendering hair :)
I am doing more bald now for sure. Have been using IDL lighting but the hair extends render time to forever. Last one I did took 20+ hours and was only 2/3 complete so I stopped it. My system is very old and can't handle the newfangles methods :(
estherau ( ) posted Sun, 31 October 2010 at 8:27 AM
But even transmapped hair extends your render time?  isn't that no different to clothes or anything else?
Dave-So ( ) posted Sun, 31 October 2010 at 8:36 AM
yes, everything extends it. I've been doing a lot of nudes lately...see at RDNA under the same name.
Actually, if you look at this image, the hair had a ton of going through the model problems, and it came out looking not too bad...although the lighting at the hair is a bit darker..covers up the problems :)
NUDITY WARNING -- if you go to large image and look at the neck, you will see it is jagged. that is from removing hair that was sticking though...bad work on my part..but the focus goes to the breasts, so you miss that :)
http://www.runtimedna.com/gallery/displayimage.php?album=lastupby&cat=0&pos=2&uid=13668
And there you have a tip to the OP...lighting is your friend, especialy in postwork where you can darken stuff to hide flaws.
estherau ( ) posted Sun, 31 October 2010 at 9:05 AM
And there you have a tip to the OP...breasts are your friends,
hehe.  nice render.  fringe would probably fall towards the floor a bit.
Hair is your enemy
DarksealStudios ( ) posted Mon, 01 November 2010 at 4:28 PM
I dont know much about doing the cloth syms/ dynamics in poser,  and what not, but had you thought about the possibility that the hair wont collide because of the way the normals are facing?
My Store   My Gallery    Contact
Elfwine ( ) posted Tue, 02 November 2010 at 2:19 AM
Can ya stick a bone in a braid to make it easier to move? scratch scratch
 Don't sweat the petty things, and don't pet the sweaty things!  ; )
