Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 7:25 pm)
Maybe it's not quite what you'Re looking for, but here:
and here:
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2733625
are two very infromative topics about eyes.
Perhaps they can help you, finding a solution of what you'Re looking for.
The included morphs are:
Lac-Morph1
Lac-Apart
Lac-Out-In
Lac-Up-Down
Lac-xScale
Lac-yScale
Lac-zScale
I hope this helps you with your problem. The morphs affect the lacimal only, they do not affect the rest of the eye socket. It is possible that the real seat of your problem is the position of the eyes in relation to the eye sockets, rather than the lacimals themselves. In that case you may need to move the eyes backwards slightly, or to scale them down. To do that you could use my freebie "UNIVERSAL Move Both Eyes at Once" from sharecg.
lesbentley,
Thanks for the work and help on this. I will give this a try tomorrow and let you know. I did scale the eyes and also moved them on the x and y translation but this was as close as I could get.
No matter what I tried though, I still could not get the corner eye tissue to have a skin color, it only renders white. Not sure why that is because I have seen some character here with a lacimal skin tissue color to it. Although, it is just a little.
I will play with this some and post a reply. Thanks.
Jeff
Development on: Mac Pro 2008, Duel-Boot OS - Snow Leopard 10.6.6 &
Windows 7 Ultimate 64bit, 2 x 2.8 GHz Quad-Core Intel Xeon , 10GB
800 MHz DDR2 RAM, NVIDIA GeForce 8800GT.
Quote - No matter what I tried though, I still could not get the corner eye tissue to have a skin color, it only renders white. Not sure why that is because I have seen some character here with a lacimal skin tissue color to it. Although, it is just a little.
Whoops. I think I misunderstood your original post "Here, I am trying to get it to look like the lacimals are a bit wider** from a photo reference I have". I thought you were wanting to change the size of the lacimals, not the colour!
If you post a screen shot of the material set up for the lacimals, it might give us a clue as to what's wrong.
Quote - > Quote - No matter what I tried though, I still could not get the corner eye tissue to have a skin color, it only renders white. Not sure why that is because I have seen some character here with a lacimal skin tissue color to it. Although, it is just a little.
No, you were correct, they were two different problems. First, was the size and shape of the eye corner lacimals Second was the fact no matter what I tried it seemed the eye lacimals did not render any skin color, only white. I think you may have fixed the first problem with the morphs. While I did not have much time today to do much due to Election Day work, I did test it and think this may help. As to the color problem always being white, I will check the material room and post a screen shot of the lacimals to look at later this week per request.
Thanks again to all for the help.
Jeff
When I inject the morphs you sent me, I get an error saying it can't locate a .jpg file "cools1" I believe the name was or something like that. If you need the exact name let me know and I will do it over again. Kind of strange because I don't know if the morphs are linked to any .jpg files.
Let me know what you think about the eyes and if they look OK to you. I moved them as well using your morph and also did so on the translate dials.
Thanks.
Jeff
I think the eyes look much better now.
Quote - When I inject the morphs you sent me, I get an error saying it can't locate a .jpg file "cools1"...
There are no references to any material or image file in the Lacimal_INJ.pz2, so I can't think of any reason Poser would give you an error about a missing jpg file when loading the morph. Neither do I have anything containing the words "cools1" or "cools" or "cool" in my runtime. This is a complete mystery to me, it should not happen.
Quote - I moved them as well using your morph and also did so on the translate dials.
If you moved the eyes directly via the translate dials, there is a problem you need to watch out for. Most normal pose files, that is to say those for setting the pose of the figure, rather than INJ or MAT, will contain translation data for the eyes, and will thus reset the eyes to zero translation if applied to the figure.
In my oppinion the best way to translate the eyes in this sort of circumstance to use ERC to slave the translations of the eyes to the morph. There is some info on doing that in this thread. The thread is actually directed at a diffrent problem, but the method of slaving the eyes is the same. Alternatively you can use the "UNIVERSAL Move Both Eyes at Once".
I tried adjusting the V4 morph, but I did not see it do anything to the eye. The photo shown here is the best I can get it and if you try using the "lacimals size" morph dial it does not really adjust anything I can tell. So, I am not sure what I am doing wrong. Is the skin in the corner of the eyes adjusted using that morph? If so, then could it be the eye mat I am using making this not look right? I got it here, it was an eye resource for V4. Also, the skin color for the eye tissue in the corners seem to be missing and just white looking. Again, not sure why that is.
Thanks for any help or thoughts on this, I really need to get this right.
Jeff
Development on: Mac Pro 2008, Duel-Boot OS - Snow Leopard 10.6.6 & Windows 7 Ultimate 64bit, 2 x 2.8 GHz Quad-Core Intel Xeon , 10GB 800 MHz DDR2 RAM, NVIDIA GeForce 8800GT.
