Thu, Feb 13, 2:18 AM CST
Subject: Problem with option delete figure in Poserpro 2010
martial ( ) posted Sun, 31 October 2010 at 10:08 AM · edited Wed, 12 February 2025 at 10:40 PM
Bonjour
Sometime ,like now ,when using Poserpro 2010, when i have character loaded and i want to delete ,for example,a cloth on this character and replace by another cloth. i click delete figure  and i have message :Are you sure you want to delete the current figure?click cancel or ok .I click ok and nothing arrives i click again and it only result with windows turn on (like the ancient bee ) and the screen turn like whit and only thing i can do is to quit Poser
I am using Windows 7 64 bits .I have reinstalled today  Poserpro 2010 because this situation arrives more and more  But i just meet the same problem
Some suggestion???
Thanks
Zev0 ( ) posted Tue, 09 November 2010 at 5:54 AM
I have the same problem. Some times when I want to delete andy when poser starts up it does that. think you must clear the cache in poser or something, I dont know.
My Renderosity Store
ratscloset ( ) posted Tue, 09 November 2010 at 7:39 AM
The White Screen indicates that the Operating System shut the Program down. There should be a Report. If you contact Support with the details, we may be able to tell you what is happening..
Note: the clicking twice will sometimes cause the OS to think something is wrong, Poser was most likely doing the delete (creating the undo) after the first click and the second click led to the OS shutting the program down. You may need to remove your Prefences if this happens to prevent the issue from being encountered again and again.
Some things to try if this does happen is check your undo count in Preferences. Pay attention if it is specific content or if the figure has specific morphs added. I encountered a Prop that had an error, that left some ghosts when you deleted. This prop would sometimes crash Poser when deleting. I suspect because of the data that got left behind. The Vendor fixed the item once it was discovered and they were notified.
ratscloset
aka John
hborre ( ) posted Tue, 09 November 2010 at 9:21 AM
If you want to bypass the Undo feature, hold shift down while clicking delete on your keyboard.  This will hasten the delete process.  However, you will not be able to take a step backwards if you want to restore a previous scene.
santicor ( ) posted Tue, 09 November 2010 at 9:33 AM
V01f  - you  might want to consider EDITING your GENERAL PREFERNCES  so  that  andy is not in your default Poser start up.
delete andy, then  set  this in  the general  preferences  by setting the current  state w/o the figure.
This simple adjustment  changed my  life for the better.
______________________
"When you have to shoot ...
SHOOT.
Don't talk "
   - Tuco
Santicor's Gallery:
 http://www.renderosity.com/homepage.php?page=3&userid=580115
martial ( ) posted Tue, 09 November 2010 at 10:20 AM
Thanks for all yours comments
But my deafut start up scene is without figure from the beginning i use Poser So may be the problem is somewhere else Fortunally ,this situation don't occure each time i want to delete
imax24 ( ) posted Tue, 09 November 2010 at 12:03 PM
It will be no consolation to you, but this behavior doesn't happen with the Mac version of PP2010.
If you want to start with an empty scene when you start up Poser, delete Andy and make any other changes in lighting, cameras, preview window, etc. that you want to see every time. Then go into Preferences and set it to Launch to Preferred State (instead of Factory State). Then click the Set Preferred State button. Now it will launch with all the settings you made to the scene.
Markus_2000 ( ) posted Fri, 12 November 2010 at 8:46 AM
Maybe this is too obvious to mention but make sure you are running as administrator.
