DAZ|Studio F.A.Q (Last Updated: 2024 Dec 26 8:06 pm)
I have downloaded these files and they are executable. They do try to load into the "C:Program FilesDAZStudiocontent" directory, if this is not where you keep your default DAZ directory, just change it to where you do.
To find the files you will need to go to your "People/Victoria4/Dynamic Clothing/" directory and they will be there.
Hi Avros,
Thank you for answering my query. I keep everything in C:Users Sylvia DocumentsDAZ 3dStudio3content. They are there but won't load into the content manager in Daz Studio, when I search for content it comes up with no files even though they are in the right place! I normally don't have any problems so not sure what could be happening?
I hope I'm explaining myself clearly:-)
Hugs
Sylvia
Quote - Hi Avros,
Hugs
Sylvia
Hi Sylvia,
What version of D|S are you using? I beleive the freebies require D|S 3.1.2.19 - 32 bit. Dynamic clothing will not work in any 64 bit D|S version; nor do they work on a Mac.
Quote - Hi Tokejr,
I've got Daz Studio Advanced, the latest one. The Dynamic clothing I've already got is fine but I can't get these freebies into my contents to use them:-) When I search for new content it comes back with no new files!!
Hugs
Sylvia
OK, let's take this one step at a time and we'll figure it out.
Unzip one of the freebie files to a temporary directory on your hard drive - I have a folder set up I call NewZipFiles on Drive C:
I use that folder to unzip all files to and then install or copy them over.
If you can do that, and post back, we'll take the next step and see if we can figure it out.
I didn't download everything but out of the ones I did get..only one had the wrong path..the chef's hat. It didn't specify the content folder, after I put that in it installed fine.
I have my Daz program installed to 'program files' on my C drive...and that is where I install all of my dynamic clothing because thats where my daz people are...
Example:
C:Program FilesDAZStudiocontentPeopleVictoria 4DynamicClothingRuffleSkirt
Some of them go into the 'props' folder in Content:
C:Program FilesDAZStudiocontentDynamic Clothing PropsHatTest
Hope that helps.
“For those who believe, no proof is necessary. For those who don't believe, no proof is possible.”
[Stuart Chase]
Attached Link: http://www.renderosity.com/mod/freestuff/details.php?item_id=62463
Hey folks,For those of you downloading and installing the freebies from OptiTex, I've done a few quick textures for them.
Texture files for DAZ STUDIO Dynamic clothing. Included are textures for some of the OptiTex Freebies (http://www.optitex-dynamiccloth.com/Freebees.html?1290143573531) and for the long pants in the paid Ultimate Pattern Design kit (http://www.daz3d.com/i/shop/itemdetails/?item=11300) . The clothing NOR these textures will work in Poser.
Now, make no mistake, I'm no texture artist , but these textures are a bit better than the ones that come with the freebies. They do, at least, have seams and hems.
Enjoy.
Quote - Well, I have mine installed to C:DazStudioContent and I had to change the path on each installation. If you have a non-ProgramFiles installation, you will have to change the Destination Directory for every file.
Yes, its set up to include the "program files" folder in the path. If you install any other way you will have to change it to your own path....but I'm thinking it needs to be installed wherever your "people" folder is where V4 and M4 are installed to work properly.
In any case...I installed it to the path it called for within the main daz program and had no problem with DS recognizing it.
I was just really glad to get some dynamic stuff for free for a change...lol
[Stuart Chase]
For anyone who hasn't found this yet...
Free dynamic stuff for Daz Studio at Optitex:
Also at sharecg:
http://www.sharecg.com/pf/full_uploads.php?pf_user_name=optitex
[Stuart Chase]
