Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 7:25 pm)
I've seen this behavior recently, while working on a fairly simple scene. I had to save the scene and close P8 down, then start it up and open the scene fresh to get the full render to finish. I put it down to having Poser open all day, and having too many unwanted textures loaded before trying to render. ;0)
Hi Anniebel, some times. It's not a biggie for me. My RAM just gets clogged up so I back out of Poser and do a re boot and do a clean up (delete temp, cache etc.). It happens when I have high activity for a long time ( going into and out of Poser, Vue, Carrara). I would suggest before doing any complex rendering, do the above first (clean out the garbage). Jan
Ok I wiil keep that in mind for next time, thanks.
The best & most beautiful
things in the world cannot be seen nor touched... but felt in the
heart.
Helen Keller
My
Gallery
My
Freebies
My
Store
I am having the same problem also, I have cleaned out the temp cashe and shut poser down and restarted with no resolution to the issue. I even increased my bucket size in an effort to solve the problem. Is there anything else that can be done for this? I am running an i7 w/windows 7 and Poser 8 at the moment. I ahve PP10 loaded but am afraid to use it right now since I am having this issue with 8. I am running P8 in 32bit and have PP10 set for 64bit.
I was doing a render today, when Poser8 just stopped/cancelled the render without an error message. I came back to check on the render process & the image was 3/4 done, but the render task bar had disappeared like when you hit cancel but I hadn't in this case. I finished the image by spot rendering the bottom 1/4, so I got the image done. Poser still functioned when I came back to it, so it hadn't locked up or crashed, but the image was incomplete. I am wondering why the render stopped & cancelled itself without an error message, does anyone have any experience with this? This has never happened to me in any other Poser version.
The best & most beautiful things in the world cannot be seen nor touched... but felt in the heart.
Helen Keller
My Gallery My Freebies My Store
