Sun, Feb 2, 4:56 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 4:55 pm)
Subject: Poser8 Rendering Question
Anniebel ( ) posted Tue, 30 November 2010 at 9:02 AM · edited Tue, 14 January 2025 at 1:37 AM
I was doing a render today, when Poser8 just stopped/cancelled the render without an error message. I came back to check on the render process & the image was 3/4 done, but the render task bar had disappeared like when you hit cancel but I hadn't in this case. I finished the image by spot rendering the bottom 1/4, so I got the image done. Poser still functioned when I came back to it, so it hadn't locked up or crashed, but the image was incomplete. I am wondering why the render stopped & cancelled itself without an error message, does anyone have any experience with this? This has never happened to me in any other Poser version.
The best & most beautiful things in the world cannot be seen nor touched... but felt in the heart.
Helen Keller
My Gallery                       My Freebies                        My Store
DreamerZ_Loft ( ) posted Tue, 30 November 2010 at 10:21 AM
I've seen this behavior recently, while working on a fairly simple scene.  I had to save the scene and close P8 down, then start it up and open the scene fresh to get the full render to finish.  I put it down to having Poser open all day, and having too many unwanted textures loaded before trying to render. ;0)
Plutom ( ) posted Tue, 30 November 2010 at 10:23 AM
Hi Anniebel, some times.  It's not a biggie for me.  My RAM just gets clogged up so I back out of Poser and do a re boot and do a clean up (delete temp, cache etc.).  It happens when I have high activity for a long time ( going into and out of Poser, Vue, Carrara).  I would suggest before doing any complex rendering, do the above first (clean out the garbage).  Jan
Anniebel ( ) posted Tue, 30 November 2010 at 3:24 PM
Ok I wiil keep that in mind for next time, thanks.
Helen Keller
shadowhawk2zero ( ) posted Thu, 09 December 2010 at 8:51 PM
I am having the same problem also, I have cleaned out the temp cashe and shut poser down and restarted with no resolution to the issue. I even increased my bucket size in an effort to solve the problem. Is there anything else that can be done for this? I am running an i7 w/windows 7 and Poser 8 at the moment. I ahve PP10 loaded but am afraid to use it right now since I am having this issue with 8. I am running P8 in 32bit and have PP10 set for 64bit.
Plutom ( ) posted Fri, 10 December 2010 at 7:47 AM
Have you defragged yet?  Jan
shadowhawk2zero ( ) posted Fri, 10 December 2010 at 8:49 AM
My last defrag was about 2 months ago but I ended up rendering the image in PP10 and it rendered without an issue the first time. I guess I need to break down and start messing around with PP10 and leave P8 alone. Not sure why PP10 did it so easily where P8 failed.
