Mon, Jan 27, 1:22 AM CST
Subject: Point light replication
krickerd ( ) posted Wed, 01 December 2010 at 10:06 PM · edited Sun, 26 January 2025 at 5:09 AM
I had an idea to make a simple string of lights, like to go around a Christmas tree.  I created a string of spheres in a 6 ring helix in Hexagon.  It was easy.  But now I'd like to add a point light with a brightness value of 1 or so to each one.  Not so easy.  Can you think of an easy way to position a point light at each sphere?  I exported the group as a 3ds file so all of the spheres would import individually.  I could replace each one with a point light one by one (what a pain).  I also can convert it to an area light.  Not quite what I'm after I'm afraid.  I could play with the latter to see if it would do but I thought I would ask for a solution for what I really want.  Too bad you can't use lights as ecosystems.  That would be closer to a solution.
bigbraader ( ) posted Thu, 02 December 2010 at 2:57 AM
Try "Replace by..." under the edit tab. You should be able to select all the objects at once and replace it with e.g. pointlights.
Lars "bigbraader"
krickerd ( ) posted Thu, 02 December 2010 at 11:13 PM
I did that but it just replaced the many spheres with one light.  However I think converting to an area light may be good enough.  I'll have to experiment with this more later.  At the moment I'm playing with an idea in Carrara.
thd777 ( ) posted Fri, 03 December 2010 at 8:35 AM
Hmm, did you make sure that spheres were not grouped together? If I do this (select all spheres and then use the "replace by command") with a set of replicated spheres that are NOT grouped together, I get each individual sphere replaced by a point light. If they are grouped, I get one light as I would expect because in agroup they count as one object. This is in Vue 9 and 8.5 Infinite.
Ciao
TD
krickerd ( ) posted Sat, 04 December 2010 at 12:22 AM
Okay that worked.  I must have had them grouped the first time.  However even at power 1 the light is overpowering.  I will have to play with this to get it to look right.
thd777 ( ) posted Sat, 04 December 2010 at 6:48 AM
Quote - Okay that worked.  I must have had them grouped the first time.  However even at power 1 the light is overpowering.  I will have to play with this to get it to look right.
There are several things you can do for the overpowering lights:
  • reduce power below 1 by typing in the value.
  • darken the color
  • use a custom fall-off filter to reduce light overlap
  • scale up the scene
Ciao
TD
