Hmm, did you make sure that spheres were not grouped together? If I do this (select all spheres and then use the "replace by command") with a set of replicated spheres that are NOT grouped together, I get each individual sphere replaced by a point light. If they are grouped, I get one light as I would expect because in agroup they count as one object. This is in Vue 9 and 8.5 Infinite.
Ciao
TD
Quote - Okay that worked. I must have had them grouped the first time. However even at power 1 the light is overpowering. I will have to play with this to get it to look right.
There are several things you can do for the overpowering lights:
reduce power below 1 by typing in the value.
darken the color
use a custom fall-off filter to reduce light overlap
scale up the scene
Ciao
TD
I had an idea to make a simple string of lights, like to go around a Christmas tree. I created a string of spheres in a 6 ring helix in Hexagon. It was easy. But now I'd like to add a point light with a brightness value of 1 or so to each one. Not so easy. Can you think of an easy way to position a point light at each sphere? I exported the group as a 3ds file so all of the spheres would import individually. I could replace each one with a point light one by one (what a pain). I also can convert it to an area light. Not quite what I'm after I'm afraid. I could play with the latter to see if it would do but I thought I would ask for a solution for what I really want. Too bad you can't use lights as ecosystems. That would be closer to a solution.
