Thu, Jan 23, 11:26 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
Carrara Free Stuff here.
Subject: More Chess Nonsense
drawbridgep ( ) posted Sat, 18 December 2010 at 12:26 PM · edited Thu, 23 January 2025 at 11:21 AM
I thought I would share a few shots from my latest render.
Here's the wireframe.
Phillip Drawbridge
Website
Facebook
The render straight out of Carrara
Phillip Drawbridge
Website
Facebook
drawbridgep ( ) posted Sat, 18 December 2010 at 12:28 PM
And the postworked one.   I Like the Carrara version too, but really had black and white in my head when I started.
Please go to the gallery to see it in it's glory.
Phillip Drawbridge
Website
Facebook
GKDantas ( ) posted Sat, 18 December 2010 at 3:32 PM
Very good render, maybe a printscreen from light setup?
Follow me at euQfiz Digital
drawbridgep ( ) posted Sat, 18 December 2010 at 5:29 PM
Only two lights. One from the left for the window light and a blue faint light on the right. That's all. The hdri is just for reflection.
Phillip Drawbridge
Website
Facebook
Analog-X64 ( ) posted Sat, 18 December 2010 at 10:28 PM
Fanstastic job. Love it.
Antaran ( ) posted Sat, 18 December 2010 at 10:41 PM
Gorgeous renders! And very nice lighting. I'm amazed it was done with only 2 lights! What's the HDRI? Is it your own or is it available somewhere?
drawbridgep ( ) posted Sat, 18 December 2010 at 11:39 PM
Attached Link: Light Probe Images
The HDRI is one of Paul Debevec's, but maybe not.  But he has some cool ones that I also use a lot.   I've attached the link.  I use St Peters a lot, (but not this time).
Phillip Drawbridge
Website
Facebook
GKDantas ( ) posted Sun, 19 December 2010 at 6:23 AM
Did you converted to panoramic HDRI? Because Carrara dont use this HDRI very well, but for reflections will work fine... well we can use JPG images as HDRI light in Carrara anyway.
Kixum ( ) posted Sun, 19 December 2010 at 10:14 PM
I'm assuming you did not use the raytraced DOF (at leas it doesn't look like it).
If you turn that on and jack up the quality, it will harden the photo-realism of it but it will also burn some electrons.  Fortunately for you, you don't have a lot of transparency (that I can see) and that will help.
-Kix
Antaran ( ) posted Mon, 20 December 2010 at 8:29 AM
Thank you for the lightprobe link -- very useful resource
Another question I have: when using Carrara's DOF, do you find it better/more realistic than adding it in postwork? And what are the conditions in which you would deem it much more preferable than postwork even with the additional render time?
GKDantas ( ) posted Mon, 20 December 2010 at 2:24 PM
A way to get a more real DOF in postwork is using DOF Pro for Photoshop, it use the depth map layers to adjust thye DOF in the postwork, using real distances, so very believeble:
http://www.dofpro.com/
drawbridgep ( ) posted Tue, 21 December 2010 at 8:03 AM
I'll check out DOF Pro.    I don't think Carrara does that bad a job.  At least it gets the depth better than I would be able to manually in PS.   And the more I can do in Carrara the better.   I really only ran an infra-red filter on this one to give it a monochrome feel and bring out the halation on the white pieces.
Just for kicks I ran the render again with raytracing and cranked up the detail.   There's really not a lot of difference at this resolution.  Maybe if I rendered it larger it would be more pronounced.
Yeah, no transparency.   I've rendered this set in glass before (with IBL) and it's a painful experience.   Maybe when I get my quad core I'll try again.  :)
I've also rendered it, in glass, with IBL in BRYCE.   That one took "a while"
Phillip Drawbridge
Website
Facebook
drawbridgep ( ) posted Tue, 21 December 2010 at 8:05 AM
Quote - well we can use JPG images as HDRI light in Carrara anyway.
I meant to pick up on this before.   How do you do this?  Where does it get the light source information from?  I would guess it would go on colour?
Phillip Drawbridge
Website
Facebook
GKDantas ( ) posted Tue, 21 December 2010 at 10:02 AM
Use Map in the background, Carrara will use color information to light the scene... my first pack of background was all JPG images.
drawbridgep ( ) posted Tue, 21 December 2010 at 10:13 AM
ha.   I had no idea it could do that.  I thought it only got lighting information from the HDRI.    Off to try.
Phillip Drawbridge
Website
Facebook
drawbridgep ( ) posted Tue, 21 December 2010 at 10:29 AM
Well what do you know.  All this time I've been faking HDRI with Photomatix and I could have probably got away (some of the time) with jpegs.    As long as there's nothing reflective in the scene that works pretty well.
Phillip Drawbridge
Website
Facebook
UVDan ( ) posted Fri, 31 December 2010 at 1:35 AM
Forum Moderator
Sweet job!
