Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
Attached Link: Light Probe Images
The HDRI is one of Paul Debevec's, but maybe not. But he has some cool ones that I also use a lot. I've attached the link. I use St Peters a lot, (but not this time).---------
Phillip Drawbridge
Website
Facebook
Did you converted to panoramic HDRI? Because Carrara dont use this HDRI very well, but for reflections will work fine... well we can use JPG images as HDRI light in Carrara anyway.
Follow me at euQfiz Digital
I'm assuming you did not use the raytraced DOF (at leas it doesn't look like it).
If you turn that on and jack up the quality, it will harden the photo-realism of it but it will also burn some electrons. Fortunately for you, you don't have a lot of transparency (that I can see) and that will help.
-Kix
Thank you for the lightprobe link -- very useful resource
Another question I have: when using Carrara's DOF, do you find it better/more realistic than adding it in postwork? And what are the conditions in which you would deem it much more preferable than postwork even with the additional render time?
A way to get a more real DOF in postwork is using DOF Pro for Photoshop, it use the depth map layers to adjust thye DOF in the postwork, using real distances, so very believeble:
http://www.dofpro.com/
I'll check out DOF Pro. I don't think Carrara does that bad a job. At least it gets the depth better than I would be able to manually in PS. And the more I can do in Carrara the better. I really only ran an infra-red filter on this one to give it a monochrome feel and bring out the halation on the white pieces.
Just for kicks I ran the render again with raytracing and cranked up the detail. There's really not a lot of difference at this resolution. Maybe if I rendered it larger it would be more pronounced.
Yeah, no transparency. I've rendered this set in glass before (with IBL) and it's a painful experience. Maybe when I get my quad core I'll try again. :)
I've also rendered it, in glass, with IBL in BRYCE. That one took "a while"
Phillip Drawbridge
Website
Facebook
Use Map in the background, Carrara will use color information to light the scene... my first pack of background was all JPG images.
Here's the wireframe.
Phillip Drawbridge
Website
Facebook
