Sun, Sep 22, 10:29 PM CDT
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 22 10:18 pm)
Subject: how to apply the original dimension of background pictures?
p3t2 ( ) posted Sat, 25 December 2010 at 1:33 PM · edited Sun, 22 September 2024 at 10:27 PM
hi guys,
amateur asking a stupid question.
when I imported a background picture, Poser asked to adjust the dimension of the current window to match that of the background picture.
but no matter I chose "no" or "yes", the background picture imported showed with a much smaller dimension, which did not match my idea of the screen, and usually with a obviously twisted width/height ratio.
the original dimension of the background picture is 2700/2700, but when imported directly into poser, no matter I chose to adjust the current window to match the background picture or not, its dimension changed to smaller than 1000/1000.
how can I apply a background picture with its original dimension in Poser directly without using any image-editing software for post-work?
thank you very much for your helps!
nruddock ( ) posted Sat, 25 December 2010 at 6:37 PM
If the version of Poser you're using is P6, you have to also increase the "Max Texture Size" (found in the Render Settings) to a value at least as large as the longest dimension of the image you're trying to use.
You should also make sure you have applied the latest Poser update.
p3t2 ( ) posted Sat, 25 December 2010 at 7:33 PM
many thx.
I will try your advice.
hborre ( ) posted Sat, 25 December 2010 at 8:08 PM · edited Sat, 25 December 2010 at 8:10 PM
Online Now!
You can also apply your image to a flat, one-sided plane and set your dimensions on the y- and x- scale.  Afterwards, change the overall scale to whatever size you desire.  To avoid casting shadows on the plane, connect your image node in the material room to the ambient_color and set it's value to 1.  You can achieve the same affect by also connecting to alt_diffuse.  Make certain the plane's cast shadow is turned off on it's properties panel.  An example can be found here:
http://www.renderosity.com/mod/gallery/index.php?image_id=1884989&user_id=343328&np&np
p3t2 ( ) posted Sat, 25 December 2010 at 10:03 PM
thank you very much, I will try it.
SamTherapy ( ) posted Sun, 26 December 2010 at 7:38 PM
Why even bother?  You won't get a realistic render if you are rendering an image with a flat plane for a background.  So, to make life easier, just render without it, save your render as PNG or TIF, then comp the background in Photoshop.
