DAZ|Studio F.A.Q (Last Updated: 2024 Dec 19 7:58 pm)
Hi Groade,
Is this the sort of thing you're after? It's rendered in Daz with M4 - all I did was remove all the textures, change the Diffuse colour to pure white, then also change the Glossiness to pure white and set it at 0%
I then rendered using the Cartoon setting under Render - Render Settings - Render Style (Change it from Normal to Cartoon)
It's just under normal Daz lights.
Cheers :)
Thanks, that looks darn close.
Here is what the very helpful Miss Nancy told me when I asked them about DAZ
*I don't use D|S, but if it has edge-blend node or falloff shader, then the answer is yes. if not, then illuminate the figure with a single infinite light in front view. the light should be located at whatever rotation causes it to be zeroed directly in front of the figure. the resulting render of an all-white figure will look the same as a falloff shader render.
Does DAZ have an edge-blend node or falloff shader?
These forums rock! You get responses to questions so quick!
I'm slightly hesitant to say 'no, it doesn't have an edge-blend node or falloffshaders' as I think the real answer to that is 'it doesn't have anything directly comparable in the Basic or Advanced Daz Studio 3 pallettes, but I think both are possible if you know more about it than I do' :)
I know it can render both translucency and sub-surface scatter effects so I suspect it does have those shader capacities, but I'm afraid I'm not knowledgeable enough about that side of it to say for sure, sorry!
I've just given it a shot with the suggestions of the infinite light (named a Distant Light in Daz) and it gives an an identical result to the screen grab above. Changing the Ambient value to pure white and dropping its strength to 2% seems to help remove some of the shadows, as does leaving Glossiness at 2% rather than zero, but it's pretty much the same.
Hope you can find an answer on the falloff :) And I agree, I've had several times when I've been very very thankful to kind folks with better brains than mine here ;)
I asked this question on the Poser forum and Miss Nancy gave me a very helpful answer in the link below.
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3745802&ebot_calc_page#message_3745802
Is DAZ Studio able to do something like this?
Any information would be greatly appreciated! Thanks!
