Sun, Feb 16, 3:13 PM CST
Subject: Texturing clothes for poser
angiexx2 ( ) posted Sat, 22 January 2011 at 1:08 PM · edited Thu, 13 February 2025 at 3:14 AM
Ok I have the uv map have made the texture how do I get that into poser to use and also save it as a mat file ?
I have mat pose edit but every tutorial have tried just doesnt seem to want to work.
Am on poser pro
Thanks
Angie
hborre ( ) posted Sat, 22 January 2011 at 1:31 PM
Online Now!
Are you familiar with the Material room?
angiexx2 ( ) posted Sat, 22 January 2011 at 2:47 PM
no am not familiar with the material room,
I made the texture by using uv mapper to get the template, then textured it in psp x2 and saved the textured one as a jpeg
hborre ( ) posted Sat, 22 January 2011 at 5:44 PM
Online Now!
If that is the case, I would suggest you open a character with associated textures already loaded and look at it's node structure in the material room.  Don't look at complicated arrangements, it will just confuse you.  You just want the basic setup to get an idea how nodes are connected.
hborre ( ) posted Sat, 22 January 2011 at 6:26 PM · edited Sat, 22 January 2011 at 6:26 PM
Online Now!
Here is a simple node arrangement for skin texturing characters within the advance tab of the material room.  This is a basic texture for Miki 2, and is predominantly how all objects and characters are textured.  But, as you can see, many other different image maps can be connected to the Posersurface which can create surface depth and light responsiveness.  When you populate all the material zones of your character/object, you can ultimately create an mc6 file within the Materials category in your library.   To convert the mc6 to a MAT Pose, you need to open the file in a text editor, and change *mtlcollection* to *figure* or *$current* (props) and change the file extension to pz2.  Save the file into your Poses category folder.  Be aware, the MAT Pose format for applying textures to figures may, in the future, become obsolete.
angiexx2 ( ) posted Sun, 23 January 2011 at 7:00 AM
Thanks
I looked at your and cannot see image map am on poser pro 7 so not sure if it would be in a different place or where to find it
angiexx2 ( ) posted Sun, 23 January 2011 at 7:08 AM
ok found the image map and brought my texture in
angiexx2 ( ) posted Sun, 23 January 2011 at 10:23 AM
but cant get it on the dress
hborre ( ) posted Sun, 23 January 2011 at 10:46 AM
Online Now!
Can you provide a screencap of your material room setup?
angiexx2 ( ) posted Sun, 23 January 2011 at 10:58 AM
Have attached one
hborre ( ) posted Sun, 23 January 2011 at 11:04 AM
Online Now!
That particular image post is for the inner mouth.  Do you have an actual MR cap of the torso or larger body area?
angiexx2 ( ) posted Sun, 23 January 2011 at 11:13 AM
Sorry I didnt realise
its attached
hborre ( ) posted Sun, 23 January 2011 at 12:30 PM
Online Now!
Is the Color_Texture node your new texture?  If so, you will need to connect it to your* PoserSurface*  the same way as the Image_Map_2 node.  This will effectively replace the old image map with the new.
angiexx2 ( ) posted Sun, 23 January 2011 at 12:32 PM
No that is how it came up when did that screen shot
its how to connect them that is stumping me
PhilC ( ) posted Sun, 23 January 2011 at 12:36 PM
Click and drag the little plug icon top left of the image map into the little socket icon on the right hand side of the Poser surface.
angiexx2 ( ) posted Sun, 23 January 2011 at 12:45 PM
Thanks Phil will go try that now
angiexx2 ( ) posted Sun, 23 January 2011 at 12:55 PM
Phil thank you now have my texture on my dress at last in poser
Find it alot harder than Daz 3d studio lol
angiexx2 ( ) posted Tue, 25 January 2011 at 6:53 AM
Ok have managed to texture the dress
how would I save it as a mat file ?
