Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 2:39 pm)
After having the cloths finished calculating in the Cloth room, I use File -> Export -> Wavefront OBJ -> Single Frame in "export Range" -> selecting the certain cloth piece only -> check the Export Options "As Morph Target" and "Include existing groups in polygon groups" and save it on a hdd.
Later then I can use the "Load Morph Target" option in the Properties tab of this certain cloth piece, load the previously saved wavefront.obj, set the new Parameter dial to 1 and the dyn cloth jumps into the previously draped pose, without the need of going through the cloth room all over again.
Quote - > Quote - after imorting morph target and set to 1
of course you could just export the finished sumulatoin and re morph it for the same result, but if its a piece of clothing you could re use it for different sumulatoins
example for the collar on a shirt or such
also you can skip the export to 3d-program and make your morph inside poser with magnets or morph brush just remember to spawn morph and delete magnet
it sounds like a great idea in theory to make a morph target after the clothifier does it's thing with the prop.
trouble is, it has to stay in it's home position, or the morph just explodes.
so, how do you... ? how ...? :blushing:
♥ My Gallery Albums ♥ My YT ♥ Party in the CarrarArtists Forum ♪♪♪ 10 years of Carrara forum ♥ My FreeStuff
