Sat, Nov 9, 6:47 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 08 10:28 pm)
Subject: converting clothify drapes to morph targets ???
MistyLaraCarrara ( ) posted Thu, 10 February 2011 at 12:28 PM · edited Sun, 03 November 2024 at 1:36 AM
it sounds like a great idea in theory to make a morph target after the clothifier does it's thing with the prop.
trouble is, it has to stay in it's home position, or the morph just explodes.
so, how do you...  ?   how ...? :blushing:
markschum ( ) posted Thu, 10 February 2011 at 1:38 PM
I export the prop after the cloth sim , and then import it and save it as a new prop. I never tried to make it a morph target but it should work .
ErickL88 ( ) posted Thu, 10 February 2011 at 2:06 PM · edited Thu, 10 February 2011 at 2:10 PM
After having the cloths finished calculating in the Cloth room, I use File -> Export -> Wavefront OBJ -> Single Frame in "export Range" -> selecting the certain cloth piece only -> check the Export Options "As Morph Target" and "Include existing groups in polygon groups" and save it on a hdd.
Later then I can use the "Load Morph Target" option in the Properties tab of this certain cloth piece, load the previously saved wavefront.obj, set the new Parameter dial to 1 and the dyn cloth jumps into the previously draped pose, without the need of going through the cloth room all over again.
wolfie ( ) posted Thu, 10 February 2011 at 2:19 PM
Um, can't you simply go to the menu and select "Spawn Morph Target"?  Haven't done it but I think that should work.
cfpage ( ) posted Thu, 10 February 2011 at 3:40 PM
simple set-up with cloth plane
export plane and make your morph
run simulation
import morph target
key is your export object must be in its origanal state and position
cfpage ( ) posted Thu, 10 February 2011 at 3:41 PM
making the morph
cfpage ( ) posted Thu, 10 February 2011 at 3:42 PM
run simulation
last frame
cfpage ( ) posted Thu, 10 February 2011 at 3:43 PM
after imorting morph target and set to 1
cfpage ( ) posted Thu, 10 February 2011 at 3:48 PM
Quote - after imorting morph target and set to 1
of course you could just export the finished sumulatoin and re morph it for the same result, but if its a piece of clothing you could re use it  for different sumulatoins
example for the collar on a shirt or such
cfpage ( ) posted Thu, 10 February 2011 at 3:59 PM
Quote - > Quote - after imorting morph target and set to 1
also you can skip the export to 3d-program and make your morph inside poser with magnets or morph brush just remember to spawn morph and delete magnet
