Tue, Nov 19, 10:33 AM CST
Subject: Is this too bright?
RedPhantom ( ) posted Sun, 13 February 2011 at 9:40 PM · edited Tue, 19 November 2024 at 10:25 AM
Site Admin
Does anyone else think this picute is too bright or do i need to calibrate my monitor?
Sa_raneth ( ) posted Sun, 13 February 2011 at 9:45 PM
a  link would help
RedPhantom ( ) posted Sun, 13 February 2011 at 9:55 PM
Site Admin
Sorry, internet is acting up again. Is that better?
Sa_raneth ( ) posted Sun, 13 February 2011 at 10:01 PM
it  kinda washes out her neck and  leaves head floating so i would dim the lights a  little mayhap change thier angel
markschum ( ) posted Sun, 13 February 2011 at 10:04 PM
The clothes and background look fine to me . The skin tone is very light but that might be ok.
ShawnDriscoll ( ) posted Mon, 14 February 2011 at 4:32 AM · edited Mon, 14 February 2011 at 4:33 AM
Gamma 1.8, 2.2?  Your image is the highest gamma I've seen in awhile for posted WIPs.
RedPhantom ( ) posted Mon, 14 February 2011 at 5:59 AM
Site Admin
I don't have gamma control. I'm using p8.
bagginsbill ( ) posted Mon, 14 February 2011 at 6:11 AM · edited Mon, 14 February 2011 at 6:13 AM
I think it's not so much too bright, but rather that it is over compensated - mid-tones shifted too far.
Antonia shaders are from VSS with shader gamma set to 2.2. Is that Antonia that you used?
Is tone mapping enabled? If so at what values? (There are two)
It could also just be over lit.
grichter ( ) posted Mon, 14 February 2011 at 10:05 AM
Also when using Gamma if the skin (daz characters) has the default light blue diffuse tint it will look washed out or too white-pale. There are several free scripts available to change the diffuse tint to 1,1,1 or all white on just the body of the character.
VSS rocks and it's free!
Gary
RedPhantom ( ) posted Mon, 14 February 2011 at 7:25 PM
Site Admin
I did use Antonia. I don't see a node labled as gamma correction nor do I see any with the value of 2.2. I won't argue with you because I don't know jack about vss but I don't know how I can find it to fix it.
the tone mapping is turned off.
I have one infinate light at 1% intensity. The rest are turned off.
Turning off that light didn't help either.
I don't see any blue in the material.
I included a screen shot of some of my settings.
WandW ( ) posted Mon, 14 February 2011 at 8:50 PM · edited Mon, 14 February 2011 at 8:53 PM
Something in your scene has a lot of ambient intensity, as I use an infinite light at ~30% with BB's Envirosphere when I use IDL for an outdoor scene.
BTW, if you go to Scripts>Partners>Dimension 3D>Render Firefly you will have access to a lot more settings.
RedPhantom ( ) posted Mon, 14 February 2011 at 9:24 PM
Site Admin
I don't see any different in the choice of settings in the firefly script and the render settings. Could we have different versions?
WandW ( ) posted Mon, 14 February 2011 at 9:51 PM
I'm not at my Poser computer right now, but the big difference is the script has a setting to control the IDL intensity.  However,  I noted the script as an aside; I was really wondering where all of that ambient light is coming from....
FightingWolf ( ) posted Tue, 15 February 2011 at 12:16 AM
It looks bright on my end. Not just the figure but the background as well.
RedPhantom ( ) posted Tue, 15 February 2011 at 5:46 AM
Site Admin
Just to see what would happen, I rendered it without any lights and this is the results.
bagginsbill ( ) posted Tue, 15 February 2011 at 7:24 AM
Are you using a glowing sphere around everything? Is it white?
RedPhantom ( ) posted Tue, 15 February 2011 at 8:34 AM
Site Admin
I have your hemisphere on it. It is white, but I don't know if it's glowing. I'm at work.  It has the default texture that it loads with.
bagginsbill ( ) posted Tue, 15 February 2011 at 11:24 AM
Then it is glowing white, and the scene is rendering as it should under those circumstances.
The EnvSphere doesn't come with images, but is intended that you use an image. The IDL lighting will then come from the data in the image. Since it is pure white at the moment, the lighting is the equivalent of being in a blast furnace.
If you were to load an image into the sphere, perhaps of sky or the interior of a room, then the lighting will be more realistic.
RedPhantom ( ) posted Tue, 15 February 2011 at 8:08 PM
Site Admin
I'll try that.
RedPhantom ( ) posted Wed, 16 February 2011 at 6:01 AM · edited Wed, 16 February 2011 at 6:08 AM
Site Admin
How about this? Better? Still needs work?
edit: we are currently experiancing technical difficulties please stand by.
RedPhantom ( ) posted Wed, 16 February 2011 at 6:07 AM
Site Admin
Ok, how about now
bagginsbill ( ) posted Wed, 16 February 2011 at 6:40 AM
The ambient light is better - now I can see a shadow.
I'd actually increase the main light here.
Winterclaw ( ) posted Wed, 16 February 2011 at 12:19 PM
I'm not an expert, so I should probably mention this to see what's going on here: for some reason it seems like the diffuse lighting is too high to me.  Is that correct and is that on purpose?
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
