Sun, Oct 6, 9:13 AM CDT
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 8:40 pm)
Subject: Is there a problem with triangulated mesh in Poser?
TheOwl ( ) posted Thu, 03 March 2011 at 12:09 PM · edited Sun, 06 October 2024 at 9:03 AM
I saw a conforming clothing made from Marvelous Designer in the freebies section. It deforms ok in my opinion. So then it means I can use PhilC's OBJ2Cr2 on tri meshes to make conforming clothing?
I think I saw a post from somewhere that states quads are preferred over tris in poser.
Passion is anger and love combined. So if it looks angry, give it some love!
PhilC ( ) posted Thu, 03 March 2011 at 12:23 PM
Poser and OBJ2CR2 are fine with tri's.
Khai-J-Bach ( ) posted Thu, 03 March 2011 at 12:44 PM
there can be an issue with long thin tris causing smoothing artifacts, the solution is simply to avoid long thin tri's, which is easy to do in modeling.
SamTherapy ( ) posted Thu, 03 March 2011 at 1:52 PM
Yanno, Poser will happily accept Ngons provided they're planar.  Anything non planar looks proper manky.
Khai-J-Bach ( ) posted Thu, 03 March 2011 at 1:57 PM
yup
tis why I use Ngons when I'm making things like rooms and vehicles. if it's not going to bend, it's not a problem to use Ngons with care... it's the context that matters..
markschum ( ) posted Thu, 03 March 2011 at 6:15 PM
You get problems with concave ngons, or at least I do :)
TheOwl ( ) posted Thu, 03 March 2011 at 7:50 PM
Can you guys show me examples?
SamTherapy ( ) posted Fri, 04 March 2011 at 3:26 AM
Quote - You get problems with concave ngons, or at least I do :)
That's what I said. "Non planar".
noxiart ( ) posted Fri, 04 March 2011 at 5:12 AM · edited Fri, 04 March 2011 at 5:16 AM
I just tested and Poser 8 (And I guess PP 2010, too) seems to have surprisingly little problems with n-gons.
Test shows a 7-sided cylinder with an n-gon on top.
From left to right:
soft edges - planar
soft edges - nonplanar
bevelled edges - planar
bevelled edges - nonplanar
hard edges - planar
hard edges - nonplanar
Default render settings with 80° standard smoothing angle
What surprises me also is that the "simple" hard edges render (now ?) actually better than the more "elaborate" bevelled edges.
Usually bevelled edges were to be preferred when you wanted crisp edges in Poser as they rendred more "naturally", but they also raised the mesh size quite a bit.
noxiart ( ) posted Fri, 04 March 2011 at 5:21 AM
2nd render:
aRtBee ( ) posted Fri, 04 March 2011 at 6:50 AM
from my investigations, hex's, quads and the various tri's (zigzag, diagonal, ...) behave different in DYNAMIC clothing, so they migh do so a bit while conforming as well.
There is no 'better' in this. Tri's do well as woven cloth, like linen or jeans, while quads do well as non-woven cloth, like leather or rubber.
And, instead of what sometimes is expected, high resolution meshes make cloth behave like thinner stuff, not thicker.
