Mon, Nov 25, 3:18 AM CST
Renderosity Forums / Freestuff
Welcome to the Freestuff Forum
Forum Moderators: wheatpenny, RedPhantom Forum Coordinators: Anim8dtoon
Freestuff F.A.Q (Last Updated: 2024 Nov 24 8:35 pm)
Welcome to the Freestuff Forum. The Freestuff Forum is intended for all  freestuff related postings within our community. This is a highlight area where our membership is invited to review, announce and give feedback in greater detail on various freestuff items offered.  Members can also post wishes of freestuff items they would like to see.
Notice: Links to offsite 'For Sale' items will be removed
Renderosity Free Stuff Area
Free Stuff Gallery
Free Stuff Guidelines
Subject: Antonia 1.2.0 is now out
odf ( ) posted Mon, 28 February 2011 at 7:11 AM · edited Mon, 25 November 2024 at 12:59 AM
I've just uploaded the new Antonia to http://sites.google.com/site/antoniapolygon/.
Unfortunately, the update became necessary because there was an unexpected incompatibility with Wardrobe Wizard. This is now fixed, but on the flip side, full-body morphs and poses for Antonia 1.0 and earlier that involve the hip/waist area will not work correctly with the new version.
Since the necessary modifications are very simple, I'm expecting that most of the existing content that is affected by this will soon be updated and work with the new Antonia 1.2.
I promise this is the last release update for a while.
odf ( ) posted Mon, 28 February 2011 at 7:15 AM · edited Mon, 28 February 2011 at 7:15 AM
From the README:
Please note that poses and full-body morphs made for version 1.0.0 and earlier may not work on this version, since the former 'hip2' actor has been renamed to 'hip' and the former 'hip' actor to 'waist'. The change became necessary in order to make Wardrobe Wizard support possible.
In general, it should be very easy to update files using the old actor names: replace 'hip' with 'waist' everywhere in the file, and then replace 'waist2' with 'hip'. Be careful if your file contains 'hip' or 'waist' as parts of longer words, though. For example, a brute-force replacement as described above would turn the word 'shipment' into 'swaistment'.
SteveJax ( ) posted Mon, 28 February 2011 at 8:22 AM
And don't forget to go buy the Wardrobe Wizard license if you want to give her clothing.
SaintFox ( ) posted Mon, 28 February 2011 at 8:38 AM · edited Mon, 28 February 2011 at 8:39 AM
I've just updated my poses on Antonia's Freebie-site - unfortunatly I was not able to update the description as well. So if you downloaded the Assorted Poses please download and install them again as soon as you installed Antonia 1.2.0.
I'm not always right, but my mistakes are more interesting!
And I am not strange, I am Limited Edition!
Are you ready for Antonia? Get her textures here:
The Home Of The Living Dolls
SaintFox ( ) posted Mon, 28 February 2011 at 9:20 AM
By the way There is a thread over at DAZ
http://forum.daz3d.com/viewtopic.php?t=158203&postdays=0&postorder=asc&start=160
Either you, odf, may want to post the same announcement to the thread or, if you give me the permission, I will copy your text and post it there. I do not want to "hijack" your posting without asking you first.
odf ( ) posted Mon, 28 February 2011 at 9:30 AM
@SaintFox: Feel free to copy it there.
SaintFox ( ) posted Mon, 28 February 2011 at 10:13 AM
Done! :biggrin:
jonnybode ( ) posted Sat, 05 March 2011 at 12:41 AM
Thanks a lot!
Ive been waiting inpatiently for this release since I saw your first post about Antonia, the time was not wasted as you've created an excellent character.
A big thanks to all the participants to!
SaintFox ( ) posted Sat, 05 March 2011 at 9:16 AM
You're very welcome!!
EnglishBob ( ) posted Fri, 11 March 2011 at 6:08 AM
Quote - Please note that poses and full-body morphs made for version 1.0.0 and earlier may not work on this version, since the former 'hip2' actor has been renamed to 'hip' and the former 'hip' actor to 'waist'. [...]
Just checking: these actor changes should also apply to pre-1.2 conforming items, yes? I tried LittleDragon's tank top on Antonia 1.2 last night and it wouldn't conform properly. I'm guessing this is why, although I haven't had time to try rectifying it yet.
Oh, and I assume you meant "replace 'hip2' with 'hip'" - or did the conversion script process your posting as well? :D Thanks for making this thread easy to find, anyway. Nobody else will ever use 'swaistment' in a Renderosity thread. Surely?
odf ( ) posted Fri, 11 March 2011 at 6:17 AM
@EnglishBob: It depends on how smart your replacement program is. If you replace 'hip' by 'waist' everywhere, that will automatically replace 'hip2' by 'waist2', unless you have something that can search and replace complete words only. But then you may have to check that your software takes the underscore as a word boundary and replaces the in 'hip in things like 'hip_twisty' as well.
I'm assuming the search-and-replace procedure will also fix conforming items for Antonia 1.0 or earlier to work with version 1.2, but I haven't tested that yet.
EnglishBob ( ) posted Fri, 11 March 2011 at 6:29 AM
Ah, I see - you were describing the process, whereas I was looking for the desired outcome. :)
I'm converting the LD Tank Top and the s242 jeans and t-shirt at the moment, but won't be able to try them until later due to unreasonable restrictions on having nekkid wimmin on my screen at work. :) Of course one has to rename the geometry's groups as well, if it has hip or hip2 groups.
EnglishBob ( ) posted Fri, 11 March 2011 at 3:06 PM
Yes, just to confirm - doing the search and replace on conforming CR2s and their associated OBJ geometry does make them conform to Antonia 1.2.
In fact I used Dimension 3D's Poser File Editor and UVMapper Pro, but the effect is the same...
This is LittleDragon's tank top and Scheusal242's jeans on Antonia 1.2 V3 mapping following the above process. The hair will be along shortly, now Les has made it work. :)
Lully ( ) posted Mon, 14 March 2011 at 11:31 AM
Hiya
I wanna try and make some clothes for AP but new to this model, I've just downloaded and installed all I could find on her but I have several options with regards to the OBJ's ...... AntoniaA-1.2 or Antonia-1.2?? what are the differences?
Can someone confirm which is the best to use please
Ta very muchly in advance  :)
Tools:- Win10, Dell XPS8900, ZBrush, Marvelous Designer 11, Hex 2, PSP8. PSP 2019 Ultimate, DAZ Studio, Affinity Photo, Affinity Designer, Filterforge 11, flowscape,  Classic UVMapper, and several headache tablets.
EnglishBob ( ) posted Mon, 14 March 2011 at 11:52 AM
I believe the A version has the old UV mapping. As far as clothes making goes, there's no difference.
Lully ( ) posted Mon, 14 March 2011 at 12:10 PM
Thanks EB for the confirmation, :)
