Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 20 6:55 am)
If Poser goes strange the fiirst thing I do is look in C:Documents and SettingsOwnerApplication DataPoser 7 where owner may be your userid, and delete the libraryprefs.xml file. You can also delete the ui prefs and poser.ini if you need to. They will be recreated when Poser starts but you will lose your custom settings and any added runtimes. They are still on disk but you need to add them to poser again.
If V4 or M4 is involved you need to run the bat file again to generate some files.
They are in C:Program Filese frontierPoser 7RuntimeLibraries!DAZ
I have had Poser 7 for about six months and up until two months ago the program worked fine...now none of the morphs are working. I have un-installed and re-installed poser 7 and all of my content and the morphs are still not working. When I try to use a character and the only thing that happens is the eye will go white and the leg may move slightly. What is the problem here? Thanks...
