Fri, Sep 20, 10:32 AM CDT
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 20 6:55 am)
Subject: Morphing Issues
colorfulsilk ( ) posted Mon, 21 March 2011 at 10:18 AM · edited Fri, 02 August 2024 at 7:16 AM
I have had Poser 7 for about six months and up until two months ago the program worked fine...now none of the morphs are working. I have un-installed and re-installed poser 7 and all of my content and the morphs are still not working. When I try to use a character and the only thing that happens is the eye  will go white and the leg may move slightly. What is the problem here? Thanks...
markschum ( ) posted Mon, 21 March 2011 at 12:34 PM
If Poser goes strange the fiirst thing I do is look in C:Documents and SettingsOwnerApplication DataPoser 7 where owner may be your userid, and delete the libraryprefs.xml file. You can also delete the ui prefs and poser.ini if you need to. They will be recreated when Poser starts but you will lose your custom settings and any added runtimes. They are still on disk but you need to add them to poser again.
If V4 or M4 is involved you need to run the bat file again to generate some files.
They are in C:Program Filese frontierPoser 7RuntimeLibraries!DAZ
colorfulsilk ( ) posted Mon, 21 March 2011 at 2:30 PM
Thanks markschum...
