Blender F.A.Q (Last Updated: 2025 Jan 28 1:01 pm)
Yea, thats what I was thinking, and it is how it seems to be seperating it. ...but just tonight, I re-imported the OBJ with nothing checked, and it still seperated it in the same manner.
But for kicks, lets say it is...do you know how to stop it from doing that? Is there like a "settings" for how it unwraps, or the rules it uses?
DARN! I figured it out...after the above thought, I wondered if maybe it is not cutting it up, but that it is already cut up? This is an OBJ that I mod'd in Blender, and then to Poser 7 for grouping, rigging and create of a CR2, etc. That left me with an OBJ which had seperate meshes (or in blender terms, a lot of Duplicates!) I removed Duplicates, re-ran it and voila! Only 1 vertice, out of sorts.
So....the next question is....is a UV map of this now even usable,since the vertex count is different? I am thinking so, since I've seen some workflows where they use low poly to create UV's and then subdivide afterward for a smoother model.
Can anyone let me know on that final point, I dont want to take the thread too far off topic.
I have a OBJ that I am importing into Blender 2.5x (using options Object, PolyGroups and -X90). I have created a Box UV for it in UV Mapper, and it shows if I go to edit mode, select all, and go to the UV Image/Editor view.
Whats odd, is that I can find no seams on the OBJ in Edit Mode.
So, instead, I went ahead made sure to select all, and "Clear Seams" and retry the UV Unwrap.
After the operation was complete (in Edit Mode) I switched back to the UV view, and there is a different "cut-up" of the suit!? I would expect it to be all l one piece.
Any thoughts about the OBJ import, and how it may be figuring out how to "cut up" my suit OBJ?My guess is that it is breaking it up per the grouping (i.e. Import setting for Polygroups) that I used, since there seems to be a Neck unwrap that looks similar to that group? I dont find anything that says it unwraps by group by default.
In fact, I already had did this and added seams, and it seemed to combine the cuts? Maybe there is a "how it unwraps" setting I am missing? I will keep looking, but wanted to ask.
My goal is to start anew, place seams and unwrap.
