Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
A few months ago there was a thread with many cloth sim experimental results posted. Some noted that the simple geometry I was using to demonstrate various things was not appropriate. So take this with a grain of salt as needed:
The Poser cloth room can almost always create poke through, no matter what you do to the settings. If somebody shows you settings that avoided a poke through, that just means that the settings have some impact. They do not have decisive, conclusive, always predictable impact. Just some impact.
Like if somebody punches your head, sometimes you'll pass out and sometimes you'll just say ow and hit them back. It depends on the force and the angle and the location.
Somebody may tell you "move your head to the right". In some cases, that will maintain consciousness, but in others your movement to the right will be the reason you go to sleep.
Similarly, I found situations where raising/lowering a value would get rid of a poke through in one place, but create a poke through in another place. Which means there is no "correct" value for the settings.
Thanks BB. I do not remember mentioned thread. Probable it had weird subject, because I usually read all thread about dynamic clothing and ofc yours tips refering nodes.
:) I feel better now. I thought that I do something wrong but now I see that more people have the same problems with theirs meshes.
Anyway you showed so many tricks with material nodes that I can create my own node which fix the problem. Plain displacement map works with smooth meshes. Of course displacement do not fit to draped surface with deep folds.
There is one trick which let you avoid poke through - subdivide mesh couple times :)
High poly clothes works quite ok, but I always try to create as low poly as it possible. Here you can see wireframe. Calculating dynamic with Antonia Lo show number from 10 to 21 (do not know what these numbers means, but common dynamic clothes and V4 show over 100)
Attached Link: Dynamic cloth - the cloth room For Compleat Dummies
I found the thread, if you're interested.Yes, do feel better. In the cloth room, we are all dummies, apparently. grin
Mesh density matters quite a lot. High density makes cloth behave "thinner" like linen instead of tweed.
Mesh makes some difference too. Tri's of any sort becave like woven or knitted cloth, while quads behave like more non-woven, like leather, or rubber.
Cloth Room makes us all feel like the magicians apprentice - the Mickey Mouse type. Same spell, other pronunciation, different effect. Then some magic happens, somewhere.
have fun
visit www.aRtBeeWeb.nl (works) or Missing Manuals (tutorials & reviews) - both need an update though
When I try create one simulation with "multimesh" cloth I cannot avoid pokethru. You can see black spots on the chest. I've tried to make "scarf" (this white piece of material which cover shoulder, chest and torso) dynamic group or soft decorated.
Soft decorated group looks weird next to vaist area, over belt, which is constrained. Dynamic group fly high over shoulders. On the picture you can see soft decorated group on the top of scarf and dynamic front and back.
Is there any way to change self collision offset?
I know that I can create 2 simulations - first with habit and second with "scarf", but I prefer one.
Here is another pict where I had similar problem but finally bathrobe works quite well:
http://www.renderosity.com/mod/forumpro/media/folder_10/file_467164.jpg
