DAZ|Studio F.A.Q (Last Updated: 2024 Sep 20 4:16 am)
Conforming the clothing won't work without major tweeking and editing because, the joints for the two figures are completely different. Things like bikinis or skirts may work without a lot of work, but clothing that have sleeves and legs are going to be a real pain to fix without the use of other software.
You can use Clothes Converter or Crossdresser to fit Aiko 4 clothes to/from Aiko 3.
http://www.daz3d.com/i/3d-models/0/clothes-converter-4?item=9309&cat=&_m=d
http://www.evilinnocence.com/crossdresser
I have both pograms and use them on simple clothing meshes. They give you a fair result but can distort intricate clothes mesh (buckles, strings, etc). Also somethimes they can stuff up the fall off zones causing clothes to break apart when posing.
Important note: these conversion programs are CPU intensive.
Oops! I just noticed you didn't want to use a converter.
Well then my advise is to give up now unless you have a LOT of patience to do manual adjustment. I spent several hours getting M4 hoofs to fit to K4 on my recent render.
http://www.renderosity.com/mod/gallery/index.php?image_id=2184555
Just as amandagirl15701 says conforming (or parenting) clothing between different figures just won't work for many reasons.
Sorry but there is no easy way.
a3 is a generation 3 figure, before the new gen4 ones, it can share v3 skins but yes the grouping and joints are not compatable to a4 which is a gen4 as in v4 figure.
you would need a lot of patience to tweek clothes for one to fit anouther, deformers may be of a help here for poke thru.
http://www.aldaraproject.com/aldara/
http://www.dreamslayervisions.com
Hello I am new to the Daz/Poser gang and I work with Aiko4 a lot and I've tried google searches but didn't get much. I was wondering what are the differences between Aiko 3 and 4. Can I use stuff for Aiko4 that was made for 3, with little or no mod to the outfit without a converter??
