Mon, Feb 3, 6:46 PM CST
Subject: Save entire scene, but just frame 30
hobepaintball ( ) posted Tue, 26 April 2011 at 5:17 AM · edited Mon, 03 February 2025 at 4:02 PM
Through a series of misteps I have a complex scene set up, but at frame 30 not frame 1. I want to save just this frame and delete 1-29. There are no hair or cloth simulations at this point, so they wont be a problem. Saving just frame 1 is easy but for some reason, even after all these years I don't know how to do the reverse.
millighost ( ) posted Tue, 26 April 2011 at 5:57 AM
I do not know how to save only a specific frame of an animation without deleting frames, so perhaps you already know more than me. But this is what i would do: simply copy frame 30 to frame 1 in the keyframe editor and then delete keyframes 2-30. The effect would be the same, wouldnt it?
hobepaintball ( ) posted Tue, 26 April 2011 at 6:27 AM
My issue is most of the many many props and furniure items were added at frame 30 so its all the "stuff" I am trying to save. So now that the room is built, the lighting is set and the models are posed I want to save frame 30 as a launching point for the project.
As for deleting frames AFTER what you want to save that is simple. Lets say you want to save frames 1-20 of 30. Just go to frame 20 and in the "frame of counter" enter 20 instead of 30. Poser will notify you you are deleting frames and you are set.
dadt ( ) posted Tue, 26 April 2011 at 7:18 AM
I would go to frame 30 then use Edit/Memorise/All.
Then go to frame1 and Edit/Restore/All
You will then have your scene in the first frame.
ockham ( ) posted Tue, 26 April 2011 at 7:22 AM
Ditto dadt.  I use that method all the time when I've accidentally added something new at a later frame.
Or if you don't want to mess up the rest of the animation: Memorize only the new item, go back to 1, restore the new item.
It would be nice if Poser had a warning or a stopper when you try to add something after 1.  There's no proper reason to do that; it's always an accident.
My python page
My ShareCG freebies
hobepaintball ( ) posted Tue, 26 April 2011 at 7:33 AM
That solution is awesome, thanks for the help.
