Vue F.A.Q (Last Updated: 2024 Sep 20 5:40 am)
This is how I would do it.
Step One: Install the render cows on each of the computers, including the main computer
Step Two: Make sure that all the rendercows are the same build number and have the same level of updates etc.
Step Three: Connect all the computers to a router, using a 1/100 (i think?) LAN cable if possible this will make the farm a lot faster becuase information will be transmitted quicker.
Step Four: Start Hypervue and start looking for the render nodes.
I think that my computers automatically connected to a homegroup on the network (Im assuming you are using vista or windows 7?) and it was fairly straightforward after that.
There are a few guides on the net that might help you, ill hunt them down for you now.
Hope this helps!
EDIT: This is probalby the only one you will need...
http://www.chromesphere.com/Tutorials/Vue6/Vue_Rendercow.html
Rich
http://blog.richard-potter.co.uk
No problem, took me an age to get it to work so its good to pass that on.
when you install the render cow, right click on the little cow icon in the corner, by the clock, and then click "about" and it displays the build and version number.
This will also be displayed when you first open hypervue and it finds all the cows, but its better to do it first, less hassle, moving between computers etc.
EDIT: its a good idea to update them all straight away as otherwise one will update and youll be annoyed..
Rich
Okay....
Cables show the same thing. Cat 5 patch cords are cheaper than Cat 6 are (oh, and make sure you do =NOT= wind up getting a crossover cable. This is specifically for connecting two computers together with no switching or routing, and is used for file transfers.
Thanks Dale this makes alot of sense.
Just to confirm,
1) Render cows are to be installed on ALL computers, even the main PC that will have hypervue installed.
3) Only need x1 monitor, keyboard & mouse - if all are connected to a 4 port KVM switch.
4) I only have 10/100 onboard cards at the moment - so best option would be to buy gigabit ethernet cards for each PC, any advice on the card details/model no?
Am I right in saying that rendercow and hypervue only speed up rendering - and does not have any effect for working with in vue i.e speed up tasks when working with vue - importing poser charactors ect?
Thanks guys for taking the time to go through this with me;)
Quote - Thanks Dale this makes alot of sense.
Just to confirm,
- The main PC is to be of the higher spec in terms of cpu,memory & graphics card.
- set rendercow to launch at startup.
300GHZ?!! :D
the i7's have hyperthreading which without any fancy talk measnt hey can perform two tasks on each core, so a 4 core processor is seen as an 8 core processor instead.
Thus leading to faster renders, if you get an i7 though I would reccomend getting one that is @ 3.0ghz or above, otherwise you will feel the diffrence when doing single core tasks in other parts of your computer life, which is a realy pain.
Rich
Ok guys,
So I have installed hypervue on my main PC along with rendercow - rendercow also install on my 2nd PC. Both are currently contected to a netgear switch via their on board 10/100 cards-for the time being. And both PC are hooked up to a KVM.
However...When working on the main PC - I cannot see if the rendercow is working. And when I render something it only shows my main PC's x4 cores in the bottom resource bar? I cannot see any new option relating to Hypervue in the top tabs - edit, render ect..and there doesn't seem to be anything to show that rendercow is setup or running?
do I need to have Vue Esprit 9 also installed on the 2nd PCs along with Rendercow?
I am not currently using cat 6 - was going to get some today. Could this be causing the problem?
How do I check the builds?
Any advice would be greatly appriciated.
Thanks,
Quote - Ok guys,
Thanks,
Thanks Dan - just when I think I'm getting there-I'm not!
To use Hypervue, select 'External', then click the edit button to the right of it. There is your hypervue manager window.
I did this fine and then I get the following message in a black Vue scrn;
*Vue 9 Standalone Renderer Version 9.00 - Build 9005691 *
Initializing...OK
THIS APPLICATION HAS REQUESTED THE RUNTIME TO TERMINATE IN AN UNUSUAL WAY.
PLEASE CONTACT THE APPLICATION'S SUPPORT TEAM FOR MORE INFORMATION
(Sorry for the uppercase)
I also get a small windows like message saying;
A problem caused the program to stop working correctly.
windows will close the program and notify you if a solution is available.
I really dont know what else to try - please help before I throw it out the window!
Thanks
Hi,
Can anyone please advise on setting up x3 PC's for Render Farm?
Will I need to setup a homegroup network on each PC to start with - and is it just a case of all the PC's being conected via a network card(onboard) to a router?
Do I then just install render farm from the Vue 9 Esprit cd to each PC and have it launch at startup on the x2 PC - but not my main PC?
Sorry for the thick question - but not much of a tech when it come to PC networks
Thanks
