Mon, Feb 10, 9:15 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 10 9:07 am)
Subject: How do you meld props together into a single prop in Poser?
chimera46 ( ) posted Sun, 29 May 2011 at 8:34 PM · edited Mon, 10 February 2025 at 9:15 AM
Can you even do such a thing?
I'm looking to turn some bracelet-like primitives into a single prop, so I can then turn it into a figure to fit onto V4 using the "repleace body part with prop" function.
Any help in this regard would be appreciated.
The strong do as they can while the weak do as they must.
LaurieA ( ) posted Sun, 29 May 2011 at 8:38 PM
The easiest way is to export all the pieces as an obj file and reimport it. It'll be one obj. then.
imax24 ( ) posted Sun, 29 May 2011 at 9:49 PM
Do you lose your material zones that way?
markschum ( ) posted Sun, 29 May 2011 at 9:49 PM
Yes, export all the parts at one time using the subset option. Then import the rsulting obj.
Replace body part will use your prop instead of the body part, so her forearm for example would become the bracelet.  Is that what you want ?
SteveJax ( ) posted Sun, 29 May 2011 at 9:51 PM
What Laurie said...
LaurieA ( ) posted Sun, 29 May 2011 at 9:56 PM · edited Sun, 29 May 2011 at 10:07 PM
Quote - Do you lose your material zones that way?
Export with "Include existing groups in polygon groups" checked. Your resulting material zones will be called "Preview:1", "Preview:2", etc. if you used primitives, but you should be able to figure out what mat zones are what ;).
chimera46 ( ) posted Wed, 01 June 2011 at 8:37 AM
Thanks so much, that definitely did the trick!
Quote - The easiest way is to export all the pieces as an obj file and reimport it. It'll be one obj. then.
MistyLaraCarrara ( ) posted Wed, 01 June 2011 at 8:47 AM
what about the spawn prop thingee on the group tool?
i understand create prop, but the spawning button is mysterious.
Cage ( ) posted Wed, 01 June 2011 at 5:08 PM
Quote - what about the spawn prop thingee on the group tool?
Neither of these can be used to combine geometry.  The Grouping Tool only operates on the currently-selected actor.
One of the options will create a new prop which is composed only of polygons in the currently active group.  The other will spawn a new prop for each group on the current actor.  Danged if I can remember what either is called, without checking Poser, though.  😊
SteveJax ( ) posted Wed, 01 June 2011 at 5:44 PM
Spawn Prop is used to break an existing prop up into it's constituant groups. You can also create new groups from an existing prop and then use Spawn Props to spawn a prop of the new grouping.
MistyLaraCarrara ( ) posted Fri, 03 June 2011 at 9:07 AM
so, it doesn't work on figures?
what about P8?
haven't tried it out yet, but i read somewhere it can do morphs across body parts?
thanks. 😄
