Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 10 9:07 am)
what about the spawn prop thingee on the group tool?
i understand create prop, but the spawning button is mysterious.
♥ My Gallery Albums ♥ My YT ♥ Party in the CarrarArtists Forum ♪♪♪ 10 years of Carrara forum ♥ My FreeStuff
Quote - what about the spawn prop thingee on the group tool?
Neither of these can be used to combine geometry. The Grouping Tool only operates on the currently-selected actor.
One of the options will create a new prop which is composed only of polygons in the currently active group. The other will spawn a new prop for each group on the current actor. Danged if I can remember what either is called, without checking Poser, though.
Spawn Prop is used to break an existing prop up into it's constituant groups. You can also create new groups from an existing prop and then use Spawn Props to spawn a prop of the new grouping.
so, it doesn't work on figures?
what about P8?
haven't tried it out yet, but i read somewhere it can do morphs across body parts?
thanks.
Can you even do such a thing?
I'm looking to turn some bracelet-like primitives into a single prop, so I can then turn it into a figure to fit onto V4 using the "repleace body part with prop" function.
Any help in this regard would be appreciated.
The strong do as they can while the weak do as they must.
