Mon, Dec 23, 9:08 PM CST
DAZ|Studio F.A.Q (Last Updated: 2024 Dec 19 7:58 pm)
Subject: How to import the poser stuff into Daz Studio 4? And a light question:-)
Mariny ( ) posted Sat, 04 June 2011 at 6:38 AM · edited Mon, 23 December 2024 at 8:47 PM
Hi.. I had no problems to find the poser runtimes throught daz studio 3 preferences.. But I can't find how to import in D|S 4:-(
Somebody who can explain it to me??
And I also have a question about D|S lights.. I have a new computer and 4 cpu and 12 gigabyte RAM.. I tried to render latios light, but it took almost 40 minutes to complete 8 % so I gave up and closed:-))
IS there ANY good lights for use in D|S that don't take "100 years" to render??
Marina
LBAMagic ( ) posted Sat, 04 June 2011 at 8:39 AM · edited Sat, 04 June 2011 at 8:44 AM
I'm currently using DS3 Advance and don't have DS4 yet because I'm waiting for the 64bit version (and hopefully a better GUI, most likely as a plugin/addon).
If you are using DS4 32bit version to render then it cannot access more than 3.2GB of RAM so that maybe why the render is taking so long. Any 32bit program (even if run on a 64bit system) cannot access more than 4GB of RAM (and Windows need approx 0.8GB of RAM to run in the background). This is because of the original design limits of the 32bit system the program was made for.
Another reason renders in DS (all versions) take a long time to render is because of shadows rendering through transperancy maps in hair and eyelashes. This doesn't seem to cause an issue to Poser but to DS it does cause really long render times. I remember reading a walk around for this in Daz forum so check there for further info.
Mariny ( ) posted Sat, 04 June 2011 at 11:51 AM
Hi.. I usually use 64 bit since I have 64 bit windows 7, but the 64 bit daz studio can't handle the dynamic clothes.. Do you know if the 64 bit daz studio 4 have that dynamic clothes option?+
And when will it be on the marked??
Marina
LBAMagic ( ) posted Sat, 04 June 2011 at 11:55 AM
Hi Mariny. Sorry I don't know that much about DS4 and I couldn't see a definitive date for DS4 64bit at Daz forum. Sigh!
TheBryster ( ) posted Sun, 05 June 2011 at 6:43 AM
Forum Moderator
On the right side of the DAZ/studio 4 UI you should see a column with several tabs on it.
One of these is the Content Library. Right-click this tab and you'll get a list of options. One of these is the Search Harddrives for files. Another is  Scan Known Directories. Each of these will bring up options to get your stuff.
Also, the column on the left side will offer you access to context sensitive tutorial videos. THese are a great help.
Mariny ( ) posted Sun, 05 June 2011 at 6:51 AM
Thanks..I found it:-)
