Thu, Nov 28, 2:38 PM CST
Subject: confroming clothing - muscle deformation
ice-boy ( ) posted Wed, 08 June 2011 at 4:57 AM · edited Thu, 28 November 2024 at 2:37 PM
i made a tight suit for M4. in the pics you see that its very close ot the skin around the shoulders.the right arm is in  zero pose.   the left arm is down.
do you see how the conforming suit(shoulder) didnt bend like M4's shoulder?
i guess M4 has deformers on the shoulder for bending right?
my question is if we can copy from M4 to conforming clothes so that the bending look the same like on M4.
ice-boy ( ) posted Wed, 08 June 2011 at 4:58 AM
ice-boy ( ) posted Wed, 08 June 2011 at 5:48 AM
aha i think those are magnets right?
chriscox ( ) posted Wed, 08 June 2011 at 6:40 AM
M4 uses hiddens JSMs (Joint Smoothing Morphs I think is what is stands for) and not magnets.  I think DAZ may have  thought that the using magnets with V4 was a bit too complicated and when back to using morphs for M4.
Chris Cox
ice-boy ( ) posted Wed, 08 June 2011 at 7:21 AM
oh yes morphs. those are morphs driven by bending right?
could we copy those from M4 to conforming clothing?
chriscox ( ) posted Wed, 08 June 2011 at 11:23 AM
Quote - oh yes morphs. those are morphs driven by bending right?
Yes
Quote - could we copy those from M4 to conforming clothing?
Yes, In much the same way you add other morphs to the clothes, except you would probably want to set them up as Joint Controled Morphs (JCMs)
Chris Cox
ice-boy ( ) posted Wed, 08 June 2011 at 11:32 AM · edited Wed, 08 June 2011 at 11:33 AM
i am using Morphing Clothes from dimension 3D for transfering morphs from M4 on conforming clothing. i tryed to copy JCM and it didnt work.
i  think it would be to much work to add all JCM by hand.
could we copy it like morphs with Morphin Clothes.
chriscox ( ) posted Wed, 08 June 2011 at 10:14 PM
Quote - i am using Morphing Clothes from dimension 3D for transfering morphs from M4 on conforming clothing. i tryed to copy JCM and it didnt work.
I would think Morphing Clothes should be able to add a morph in the clothes to match the morph of a JCM (JSM as DAZ refers to them in M4).  However, I'm don't know if the are settings in Morphing Clothes to make the morph in the clothes a JCM or if you would just need to add that code to make a JCM yourself
Chris Cox
ice-boy ( ) posted Tue, 14 June 2011 at 3:51 AM
i now understand how to create JCM for conforming clothing.
i created a biceps muscle. so that when he bends the forearm the biceps moves outside like in reality.
ice-boy ( ) posted Tue, 14 June 2011 at 3:52 AM
here you can see the shoulder. its tight and close to M4's skin. like it should be. i created a shoulder morph for both sides. and then i created JCM.
ice-boy ( ) posted Tue, 14 June 2011 at 3:54 AM
you see how the shoulder look here? very good right?
ShawnDriscoll ( ) posted Tue, 14 June 2011 at 4:59 AM
ice-boy ( ) posted Tue, 14 June 2011 at 8:48 AM
having extra morphs for bending makes it look 10 times mroe realisitc. the problem is that it takes so long to make the morphs.
i am already doing modeling and texturing.
i hope i will find a faster way.
MistyLaraCarrara ( ) posted Thu, 23 June 2011 at 2:56 PM
all you need is a head to complete your own Human figure model.  you already have the hands !
moriador ( ) posted Thu, 23 June 2011 at 9:43 PM · edited Thu, 23 June 2011 at 9:44 PM
Quote - having extra morphs for bending makes it look 10 times mroe realisitc. the problem is that it takes so long to make the morphs.
It looks way, way better. You've identified the number 1 problem I have with clothing for M4, and the reason I rarely use any of it, unless I convert it to dynamic. If you did find a faster way to deal with this issue, I'm sure quite a few vendors would be very pleased to hear about it.
