Tue, Jan 14, 7:48 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 14 12:25 pm)
Subject: photo backdrops resizing on render?
dyo ( ) posted Mon, 20 June 2011 at 9:06 PM · edited Tue, 14 January 2025 at 7:46 PM
Hi people
when I import an image as a back ground at say 1600 by 1200, i set the render size to 1600 by 1200 but the render gives me white on each side of the image.
Why is the background not filling the render window ?
thanks in advance
DYO
Dyo Sloneclaw
Struggling unemployed Artist
Poser 6 on VMware Fusion windowsXp immulator on mac osx 10.6.7
bagginsbill ( ) posted Mon, 20 June 2011 at 10:42 PM
In the Background material in the node where the background image is (usually called BG Picture) there is a check box called Auto_Fit. Turn it on.
dyo ( ) posted Thu, 23 June 2011 at 9:35 PM
Thanks bagginsbill
The full render is fine, but its when i render a quick version in firefly , that the back ground pic is squashed ?
So I cant see if the image is in the right location .
regards
DYO
Dyo Sloneclaw
bagginsbill ( ) posted Thu, 23 June 2011 at 9:54 PM
I'm afraid I don't understand you. I don't know what it means to render a "quick version in firefly".
Do you mean something else than rendering in firefly? There is no "quick version" of firefly.
dyo ( ) posted Thu, 23 June 2011 at 10:01 PM · edited Thu, 23 June 2011 at 10:05 PM
Hi bagginsbill
I mean the render settings are on "Draft" not final
the back ground photo is squashed side ways with white on both sides , in a final render this does not happen .
just a bugg i guess
thanks
DYO
Dyo Sloneclaw
bagginsbill ( ) posted Thu, 23 June 2011 at 10:08 PM · edited Thu, 23 June 2011 at 10:09 PM
What OS? What version of Poser? What SR? (Put this info in your signature - and please ask everyone else to do so. It seems like I ask these questions preparing to help somebody about 20 times a week.)
I cannot reproduce what you describe.
dyo ( ) posted Thu, 23 June 2011 at 10:35 PM
Hi Bagginsbill
I have added the OS and poser version but what is SR ?
im not good with the operating systems stuff or typing for that matter :( sorry
each time I get a good image in poser i think its a small miracle :)
DYO
Dyo Sloneclaw
bagginsbill ( ) posted Thu, 23 June 2011 at 10:39 PM
SR stands for Service Release - when Smith Micro puts out an update to a previously released version of Poser to fix bugs.
I no longer have Poser 6 to compare behaviors with you. Perhaps somebody else can help.
dyo ( ) posted Thu, 23 June 2011 at 10:46 PM
Ok thanks for trying
I hope to update soon to poser 8 when I get some spare cash !!!!!!
BTW nice tatts on Ladywolf
DYO
Dyo Sloneclaw
nruddock ( ) posted Fri, 24 June 2011 at 2:12 PM
For P6, you also have to change to "Maximum Texture size" to be equal to or larger than the biggest dimension of the background image.
Rainfeather ( ) posted Fri, 24 June 2011 at 2:43 PM · edited Fri, 24 June 2011 at 2:43 PM
Try this under Settings > Render Setting then move the slider up as shown below:
Make sure the max texture size is equal or bigger than the background size (as nruddock) mentioned.
dyo ( ) posted Sun, 26 June 2011 at 11:27 PM
Thanks rainfeather and nruddock
I will keep an eye on the max texture size when rendering from now on
Dyo Sloneclaw
