Display/Figure Style or Display/Element Style
Either could be doing it. Use the menus or ...
Select it and press ctrl-alt-9 and ctrl-shift-9
I have seen this and sometimes ticking 'enable hardware shading' under the preview tab of render settings has corrected this. However it does not always solve the probelm and can create more problems in the preview.
I use Poser 13 on Windows 11 - For Scene set up I use a Geekcom A5 - Ryzen 9 5900HX, with 64 gig ram and 3 TB storage, mini PC with final rendering done on normal sized desktop using an AMD Ryzen Threadipper 1950X CPU, Corsair Hydro H100i CPU cooler, 3XS EVGA GTX 1080i SC with 11g Ram, 4 X 16gig Corsair DDR4 Ram and a Corsair RM 100 PSU . The desktop is in a remote location with rendering done via Queue Manager which gives me a clearer desktop and quieter computer room.
As an ex-trainer my definition of a dumb question was - one that was thought of but never asked. On a forum like this I accept it can be annoying if the question has been asked a number of times before no-one bothered to do search before hand.
Point is I had noticed the same thing and did not know the answer so I did not regard it as a dumb question and now, like you, I have an answer to it. So thank you PXP for asking and also BB for providing the answer to yet another of my 'I wonder why' questions.
Hey I remember it stumping me in the beginning as well. Even if this was answered before, I would not know how to find the answer via searching with any efficiency. It was easy to ask and easy to answer. No biggy.
Some hair makers have the display setting hard coded in, I believe. So, checking "Texture shaded" makes no difference. IIRC, some of Koz's hair is like this.
Quote - Some hair makers have the display setting hard coded in, I believe. So, checking "Texture shaded" makes no difference. IIRC, some of Koz's hair is like this.
For that sort of problem, you can just go into your hr2 file or cr2 file with like Notepad++ or some pure text editor for the hair or whatever and do a search for "displayMode". Replace "WIREFRAME" with "USEPARENT". I'd save the fixed versions as:
"MyHair Textured.hr2"
or something like that.
Certainly the element display style is normally coded into every actor in a cr2, and the overall figure display style is also specified in the cr2. However it's not "hard coded", you can always change the Display Style via the Display Style palette.
You should remember that there is a 'Figure Display Style', and an 'Element Display Style', and you may need to set either, or both, to get the desired style. I'm not knocking RobynsVeil's advice. Of course if you want to fix it permanently at the source, edit the cr2. But for those who may not feel comfortable editing Poser files, just use the Display palette.
Basically some hair will not display colour in the Poser preview window before a render whereas other hair products do.
I really feel silly asking this question But why is this happening? Is it controllable and if so how? or is it down to the artist/creator who made it?
Really could do with an answer to this.....
