Mon, Jan 20, 7:48 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 7:34 am)
Subject: Can I alter the clothes in Poser
art4me ( ) posted Sat, 02 July 2011 at 4:54 AM · edited Mon, 20 January 2025 at 7:47 AM
Hi
I would like to modify some clothes used in my Poser program.
For example would it be possible to make a pair of shorts from a pair of jeans by somehow cutting off the legs?
Best I could do was to group sections together and make this invisible.
Problem is that you can on select a section so it is not a accurate way to do it.
I would also like to put fraid edges on them if possible.
I attach pic of the clothing I am trying to alter
Any advice appreciated.
I am a amateur Poser user so step by step advice appreciated.
I aslo have photoshop
Thanks in advance
RobynsVeil ( ) posted Sat, 02 July 2011 at 5:04 AM
The easiest way to alter - what you want to do - clothing is in the texture file. In the material room, under Advanced, have a look at the file and path of that image. You'll want to create a trans-map and alternative image file (always work on a copy!) ... there are heaps of tutorials on how to do this in Rendo's tutorial section and Daz's as well.
Metaphor of Chooks
pakled ( ) posted Sat, 02 July 2011 at 7:22 AM
another quickie might be to see if the legs are more than one group. If you click on the bottom part of the pants, just uncheck 'visible' in the properties, and instant shorts...;)
art4me ( ) posted Sat, 02 July 2011 at 8:42 AM
hi RobynsVeil
many thanks for your reply.
From the information you gave I thought that information and tutorials for trans-map and alternative image would be easily found
See attach screenshot of a google search for 3d transmap, there is nothing relevant.
Could you please be a bit more specific, please note I am a bit of a amateur with Poser.
pakled many thanks for your suggestion but using groups and making them invisable does not give me the accuracy I need
Thanks
NanetteTredoux ( ) posted Sat, 02 July 2011 at 8:44 AM
For retexturing clothes I highly recommend Stitchwitch, a really easy and useful program.
Poser 11 Pro, Windows 10
chriscox ( ) posted Sat, 02 July 2011 at 9:28 AM
First thing that comes up when Googling for "poser trans map"
http://www.cocs.com/poser/transmap.htm
A step by step tutoria on how to make transpancy maps
Chris Cox
Kalypso ( ) posted Sat, 02 July 2011 at 9:53 AM
Site Admin
Here's a tutorial on making a transparency map   and since you mentioned making shorts here's a quick example of how I did it.
Using the jeans texture I added a layer to make the fringe and saved as a new texture map.   Then I made anything I wanted transparent black and the parts I wanted to preserve were made white including the layer with the fringe.  Make sure it's totally black though or you'll get artifacts.   Then just load your new texture map in the diffuse channel on an image node and your transparency map in the transparency channel making sure you set transparency to 1.000 and falloff and edge to 0.
markschum ( ) posted Sat, 02 July 2011 at 9:55 AM
transparency map  may give you better results.
its a simple black and white image where white is visible and black is transparent. Use the texture teplate as a guide.
If you make or modify a bump map for the pants you can make an edge that will look like a proper turned up edge.
willyb53 ( ) posted Sat, 02 July 2011 at 11:20 AM
This tutorial may help.
http://www.daz3d.com/i/tutorial/tutorial?id=985
Bill
MikeMoss ( ) posted Sat, 02 July 2011 at 11:56 AM
Hi
Using transmaps will let you do more then just cutting off the legs too.
You can make holes in them and have edges that are frayed and have a natural look.
Combine that with editing the Texture file in a program like Photo Shop (make a copy and save it under a new name) and you can fade the edges, and get lots of different looks out of the basic clothing!
Mike
If you shoot a mime, do you need a silencer?
art4me ( ) posted Sat, 02 July 2011 at 7:48 PM
many thanks
That tutorial looks good
Bye
RobynsVeil ( ) posted Sun, 03 July 2011 at 5:11 PM
Metaphor of Chooks
