Sat, Jan 25, 4:53 AM CST
Subject: Morphs not showing up in old project
ShaaraMuse3D ( ) posted Thu, 11 August 2011 at 3:45 AM · edited Fri, 24 January 2025 at 6:51 PM
I have a poser project (V4) I have been adjusting and making alterations on for a long time. There are lots of different morphs on her, and I've ran into a problem.. It has happened before, and I just bit the bullet and started from scratch, putting in the same values as I had etc...
Problem is that I am loading morphs, NBM in this case, and they don't show up. They do show up if I load the figure fresh however. Does anyone know what's causing this, and if there's any way to fix it without having to start over?
Thanks!
MistyLaraCarrara ( ) posted Thu, 11 August 2011 at 8:33 AM · edited Thu, 11 August 2011 at 8:39 AM
the channels aren't in your older model.
saving a pose asks if you want to save the morphs.  :idea:
ShaaraMuse3D ( ) posted Thu, 11 August 2011 at 8:40 AM
They are both the same version of the model , V4.2, but one is in a project file that's been around for a while, with other morphs loaded and unloaded. That's the only difference.
MistyLaraCarrara ( ) posted Thu, 11 August 2011 at 8:43 AM · edited Thu, 11 August 2011 at 8:46 AM
as i understand it, the updater thingee that runs after you install a new morph pack, only updates the V4.2 in the Daz People folder.  if you have any other V4's saved in your runtime, they won't be updated.
 edit:  if you have a utility like Injection magic, you could save your project as a character injection file, make it easier to update a fresh V4 :idea:
ShaaraMuse3D ( ) posted Thu, 11 August 2011 at 8:47 AM
Oh really, I didn't know they made actual updates to the V4 model?  That would explain a few things, and I'll just have to restart the project, saving the old morph values. Oh well. :)
MistyLaraCarrara ( ) posted Thu, 11 August 2011 at 8:53 AM
y'know, i wonder if it's possible to manually edit the updater file to point to a different V4.  worth a lil investigating.
bagginsbill ( ) posted Thu, 11 August 2011 at 8:59 AM
I'm not clear on this sort of thing (anything not rendering or lighting and I'm a noob) but...
Suppose you open that broken scene. The dials have the values you want, but are not working, right?
Load a new V4. Inject all the morphs you used (or all the morphs).
Select the old figure, click the parameters window (not sure if that is required but just do it) and do Edit/Copy or Ctrl-C (Cmd-C on Mac).
Selected the new figure. Do Edit/Paste or Ctrl-V (Cmd-V).
I'm guessing this might transfer the settings.
ShaaraMuse3D ( ) posted Thu, 11 August 2011 at 9:13 AM
I will definitely try that, thanks both of you for the insights and tips.
vholf ( ) posted Thu, 11 August 2011 at 9:23 AM
If you got the morphs from Daz3d, then yes, you need to run the updater and the new morphs will only show up for new figures you create.
If you don't want to start over though, you can load a new figure with the NBM, dial the desired values, export the geometry as a morph target, load the character you've been working on, and load that geometry as a new morph.
lesbentley ( ) posted Thu, 11 August 2011 at 1:22 PM
This thread may also have some relevance to your question, "Can you distribute the V4/M4.cr2?"
ShaaraMuse3D ( ) posted Thu, 11 August 2011 at 2:44 PM
Looks like I got a lot of different tools and options.  Thanks. :)
