You have to export each body part as a separate OBJ, unless they changed the way a multi-group OBJ morph target is read back in. This screwed me up for a long time. Phil Cooke gives the impression this can be done in his magnets tutorial but it never ended well for me.
http://www.philc.net/PTB_tutorial4-2.php
When you import a morph target, I believe the internal name for the new channel is set to the name of the OBJ file, which gets kind of messy when you do it the way I do, with each body part handled as a separate OBJ - if you put all the OBJs in the same directory, they have to have unique file names, so each body part's morph internal name will be unique.
Really, this crap is too tedious and error-prone to do by hand more than once in a lifetime. Just use a script for this kind of thing. Phil has a pretty good set of utilities for this in Poser Tool Box that are figure-agnostic. If you are working with DAZ's figures, svdl's Spawn Character script makes the whole process much less painful.
Very important to avoid any bone deformations of any kind; make sure the figure is zeroed, and do not do any bone scaling anywhere on the figure, or your morph target probably won't deform the character the way you expect.
Drop MorfromOBJ.py (swap .txt with .py) in poserscripts (main runtime). Export your figure zeroed. IK off. Scaling off. Eyes and teeth objects zeroed. Check Weld and "include existing groups" to a file. Then export a "virgin" figure (unworked) with just "include existing" checked.
You can proceed to Modeling apps from here or,,
Use kawecki's "Morpher to merge verts of two exported objects. This is not necessary but it assures success.
Use the "virgin" zeroed figure. Click on Groupng tool, up it to figure in parameter box,, now drill to python>poserscripts>Morph From OBJ.py and follow the prompts.
If you want thumbnails, Have your scene ready. After its done, close file and load your cr2 into a new window to shake the deleted objects...
Where is that dutchman?
"Use the "virgin" zeroed figure. Click on Groupng tool, up it to figure in parameter box"
Don't follow that line richardson, please paraphrase even simpler for the learning impaired such as myself =/
Zaycrow, I'm, curious what you do AFTER you use the "Load Full Body Morph" feature...
What's the next step to creating the inj/rem files we would need? Is there an "Inside-of-Poser" solution?!?
There are 3 kinds of people in the
world. Those that can count, and those that can't..
"In PP2010 it's easy. Just save out the morphs as a OBJ file and then use "Load Full Body Morph" to load your morphs. But only PP2010 has that option."
I must be missing a step because I have tried this method and it's not working..
I have PP2010 ... Maybe it's just late and I can't think but after I save as a "full body morph then what?..
Any help would be appreciated.. :)
Tara
"The best and most beautiful thing in life cannot be seen, not
touched, but are felt in the heart."
Hiya Tara,
I need more info like; did you export your obj out of poser? Did you make dialspin morphs or Zbrush alterations? But guessing here;
You export your figure in T pose IK off using a zero pose (toes point down on V4) using "file/export/wavefrontobj" to any file (you can find).
Then close your window and "file/ new" (you don't have to... this is just clean), load a new default figure (V4.2 from daz cr2 folder), zero pose it with IK off.
Select it, go to (upper bar) FIGURE/ Load Full Body Morph .. Click on Gray square and find your obj .. double click it and name it. Don't check the vertice box.. click OK.
Set body to 1
Done.. it works but not as sweet as (above) mentioned script. That script gives you the cr2 and INJ/REM.
This is good in its own way though. You don't have to jump through too many hoops.
,r
richardson; your settings wouldn't work! I believe the question was about exporting from/importing to poser and not to third party programs as that is a total different thing.
You can not use any settings when exporting/importing from Poser Pro 2010 when exporting the OBJ to be used as a morph and then loading it with "Load Full Body Morph"!!
Thank you for your help …
I imported into Zbrush from the Geom directory.. Didn't think about exporting it because I was told to bring it in from the Geom directory.
Then sculpt and export that obj to Poser 2010 and once I get into Poser 2010 and then I'm kinda lost..
Okay I will try to export from Poser 2010 and import to Zbrush with the settings you said Zaycrow and then test sculpting and export it back to Poser & create a full body morph and see it if makes a difference.. (a friend old me to then save it as a cr2 in characters folder) then use injection pose to make the morphs stick...
Love Zbrush so looking forward to getting this all set up so I can finish my new character.. :)
Thank you all! :)
Stormi, the settings I have posted was NOT for third party programs. So if richardson has it working with his settings for Zbrush you should use that, as I don't know what works best for Zbrush.
The settings I posted was to be used if you use the morph tool in PP2010 to create your morhps, export the OBJ, and load it with "Load Full Body Morph".
Oh I found out how to do it...
1) import the figure's OBJ file into ZBrush.
2) sculpt
3) export OBJ out of ZBrush.
4) load figure in Poser.
5) Poser 2010 menu Figure > Load Full Body Morph
6) Select Body
7) Find new morph dial, set it to 1.000
8) Save figure to the library.
Thank you!
My entire workflow
Load Michael in Poser 2010 turn Ik off
Set Pose to Zero
Point feet down
export it with these settings..
Weld body part seams
include existing groups in polygon groups
Load obj into Zbrush
(Sculpt) Then Export from Zbrush
Load a clean Michael IK off feet pointed down
Load full body morph
Set the FBM to 1.00
It's NOT working.... What am I doing wrong?
Accchhha.. moustashe sounds..
You said you brought him from Geometries. You need a different workflow for exporting him out of Poser's export window.
Can you still use your sculpted obj from DAZ People in Geometries?
To be clear, you open ZB4. Double Document, Import/ Poser/ Runtime/ Geometries/ DazPeople/ renamed copy of your Michael OBJ.
Activate symmetry. Sculpt it. Reset it to subD1. Export to same location.
Then,
Load a new figure (M4, V4) into your workwindow.
Set 0 pose. IK off
Click Figure/Load Full Body Morph
Click on gray square
Find and doubleclick your Zbrushed Obj (rename if needed) ok
On new figure, scroll to bottom of parameters,, "community",,, to "Other"
Set your FBM to 1.00
Having created a morph usng the morphing too0l there is an option to save a copy, but where are these copies kept? I have tried to load one by typing the name into the' load morph target '(which expects an obj ) but I have never been able to retrieve a saved morph
Thanks
